1998 s70 thermostat and ECT replacement 9186486 9144275
Has thanked: 1614 times
Been thanked: 4078 times
Been struggling with the stripped T40 on this b*stard for a few weeks. Finally popped off the fuel rail and banged the head loose with a chisel. Much easier on the 1999.
Big waves onthe beach
https://www.fcpeuro.com/products/volvo- ... 90-9186486
Cat
Cat
Beach
Beach
T5 m56
T5 m56
1999 access, note the new bolts , best $5 you will spend on a thermostat jib
1998, ugh. I stripped out the injector rail to get to the back one with a hammer and chisel t40 on those, a nice sharp bit. Hard to get flame on there around an open fuel line and soft vacuum hose
1998 again
1998 again
I will have to fix the connector on the ECT as it froze and broke while I made this repair. Good project over Thanksgiving
It’s been $7800 order year from FCP. I think I’m finished for 2025. I did order a fair amount on tariff scare which was a poor strategy but that’s on me. Gains in market far outstripped any savings from parts cost going up.
Grantkat
Year and Model: 1999 s70 GLT
Has thanked: 59 times
Been thanked: 54 times
Post by Grantkat »
abscate, you arent the only one. I will confess I did the same on the Tariff scare. I have a sequoia and still have product coming in from Japan as a result. FCP got a great deal of my business as well.
1999 S70 GLT ~193k
2014D VIDA/DICE
2007 Jeep Wrangler Unlimited ~ 315K
2008 Lincoln MKX ~130k
2008 Toyota Sequoia ~ 252k
Powered by coffee, stripped bolts, and questionable decisions.
wizechatmgr
Has thanked: 45 times
Been thanked: 129 times
Post by wizechatmgr »
Which model car does that Cat fit? =)
2023 Lexus RZ450e -66k
Does anyone have the engine side connector for a -1998 ECT harvested I can buy? I’m not sure I can save mine , worst case I’ll have to make a new one somehow.
Could it possibly be this one
https://www.fcpeuro.com/products/volvo- ... wE#reviews
I sure wish I had followed ErikV advice and done this instead…long torx driver
Agreed, it is the thermostat. A long torx driver is the key on those bolts, so the shaft points straight down into the recesses in the screw head, so you can seat it securely. I hold a long torx screwdriver in place with one hand and turn the handle with pliers in the other hand. Then just a typical routine works fine (spray penetrant, unscrew after 5 minutes). Don't waste even one second with WD-40 in this situation, it is near worthless as a penetrating oil. That's a typo from cn90, he probably means Liquid Wrench etc.
Maple syrup smell is a sign you should also check the heater core though I agree that it has nothing to do with the time it takes the car to heat up. Does the coolant level drop at all?
rolsen11
Year and Model: 00 V70, 04 S60R
Has thanked: 57 times
Been thanked: 58 times
Post by rolsen11 »
abscate wrote: 22 Nov 2025, 03:59 Does anyone have the engine side connector for a -1998 ECT harvested I can buy? I’m not sure I can save mine , worst case I’ll have to make a new one somehow.
Part number 970755 appears to be the correct harness side connector for the ECT. Not sure yet of the part numbers for new terminals and wire seals though if you need them. You might just need to be careful removing the old ones.
2000 V70 SE - Bought sight unseen in Cleveland, no longer my only car. Looks identical to my profile picture
2004 S60 R - M66 "Spaceball" manual transmission, Atacama "orange" interior, Titanium Gray metallic
Well, good news.
The sidelight connector on Shagg (1999) was listed as a two pole connector similar to the 1998 ECT so I harvested it and tried it. Might need a bit of plastic shaving but it fits well.
Looks like the radiator trigger connector, the sidelight connectors and the -1998 style ECT all work here
abscate wrote: 24 Nov 2025, 08:58 Well, good news.
This transplant, 1999 side light plug to 1998 ect connector, worked! Note that on 1999 the ECT connector goes to a standard Volvo squeeze and slide type which seals better than previous.
