Water in sunshade
99TurboBrick
Year and Model: 1999 S70 T5 Manual
Has thanked: 42 times
Been thanked: 15 times
Post by 99TurboBrick »
Hello! I just purchased a 2006 XC90. Of course the sunroof leaks! :lol:
The two A pillar drains are functioning normally. However, water is collecting in the sunshade.
Question: is the sunshade designed such that the water drains out of it and into the sunroof channels and hence out of the vehicle?
I do not detect any moisture anywhere else; nothing in the headliner, etc.
I do see some of the fabric of the sunshade peeling off at the front edge, my guess is due to the moisture.
Also, I'll add that the shade is off track. It wouldn't surprise me if the water deteriorated some of the components, and they are probably damaged.
Any insights or advice is appreciated!
ggleavitt
Year and Model: 06,08 XC90 V8
Has thanked: 26 times
Been thanked: 134 times
Post by ggleavitt »
Maybe need to adjust the sunroof. Here's a calibration post here- viewtopic.php?t=44603 , I do this upon occasion. Adjustment itself is here:
XC90 Sunroof Adjustment_1225.pdf
(375.52 KiB) Downloaded 56 times
,you should calibrate after you're completed for a final visual check on the adjustment.
99TurboBrick
And now the moon roof is stuck in the open tilted position. I've tried multiple times to close it, and now suddenly the battery is dead, the vehicle won't start, and there's a check engine light. :lol: That's gotta be one helluva weak battery to drain in just a few minutes of pushing a sunroof close button.
I'll address the battery situation, then look into the calibration info. Thanks!
Capndirk
Year and Model: 2009 XC90
Has thanked: 13 times
Been thanked: 14 times
Post by Capndirk »
There are different size batteries that fit in the tray and under the cover without modification. The smaller stock battery is terrible for even using the radio in ACC position. Get the largest AGM battery that fits. On my '09 XC90 it's H7, on my'14 XC90 it's H8. I've read that Walmart does a straight replacement within warranty, where most sellers like Costco give a pro-rated credit.
99TurboBrick
Amen to that! That's why I got this 60lb tank of a battery:
Odyssey Performance Group Size 49 Absorbed Glass Mat (AGM) Battery ODP-AGM49H8L5
The vehicle starts so quickly upon turning the key, it's remarkable.
And with that, the sunroof now closes! Now to diagnose the leak. Chatgpt says there are 4 drain holes, but everywhere where else I've heard of only 2 drains. So that's interesting.
Capndirk
Post by Capndirk »
4 drains is correct. In addition to the hoses in the "A" pillars, there are hoses that run down the "C" pillars to an area at the front of the rear wheel wells. They have the same purse-lip 90° drain fitting https://www.volvopartswebstore.com/show ... evel=24666.
Has thanked: 2199 times
Been thanked: 1852 times
Also check for windshield leaks as at this age it is possible for leaks along the top edge.
99TurboBrick
Capndirk wrote: 04 Jan 2026, 09:21 4 drains is correct. In addition to the hoses in the "A" pillars, there are hoses that run down the "C" pillars to an area at the front of the rear wheel wells. They have the same purse-lip 90° drain fitting https://www.volvopartswebstore.com/show ... evel=24666.
Peppermint has a good video showing these. Sharing for future reference:
