Coolant leak, low levels. Smoke. All over READ belt area driver side. Topic is solved
Third generation Volvo V70 wagon and XC70, and second generation S80. Are you an owner? Prospective owner? Get in here and join us! Start a new topic or comment on an existing thread.
2008-2016 V70
2008-2016 XC70
2007-2016 S80
GreenMagicMan
Year and Model: '10 XC70 3.2L AWD
Has thanked: 14 times
Been thanked: 7 times
Post by GreenMagicMan »
As titled.
2010 XC70 3.2L 204K miles. coolant leak at driver side of engine. The accessory drive belt there is now soaked.
Several weeks of coolant mysteriously being low after filling. Nothing observed on ground.
We drove up a one mile hill and smoke was coming out of engine.
Coolant leaking heating up on engine was the cause, that whole area is soaked in coolant.
It’s my understanding it could be water pump, thermostat - is that in this area? And an oil cooler connector that frequently goes bad?
So far having no luck isolating leak point. But likely have to pull battery and tray and airbox (damn torx bits again).
Are those three things in that area plus some more coolant lines? Coolant is everywhere. Coating PS lines, that belt and more. It’s not splatted on the firewall that I noticed. And there were just a few drops of coolant only making it out of the lower splash guard to snow on ground. I’m hoping it’s not a water pump.
Oh and maybe related or not: sometimes we hear a noise with a little heavier throttle than mellow driving (like uphill and more when cold). Ease off throttle and it goes away. Our V50 did the same thing.
A noise like a mechanical rattle. It seems to our ears to be coming up higher in the engine when driving. I’ve already replaced the upper torque rod aka upper engine mount that was broken.
Any advice very appreciated. Thanks!
'10 XC70 3.2L
'05 V50 T5 AWD (active)
'05 XC90 V8 (red - Dead)
(2) 2007 XC90 3.2 AWD (blue and silver) junked
Has thanked: 1497 times
Been thanked: 3810 times
Have you looked for a diagram of the Read system and cooling group? I’ll see if Alldata has one and post
I believe your3.2 is like my xc90 3.2 with the water pump being driven by pins on the power steering pump. Repair and replace is about 3 hours book time.
From your description it looks like the water pump has let go and is spewing onto the PS pump. At 200k miles, I would do the pump, thermostat and all hoses as PM
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 115 times
Been thanked: 185 times
Post by pgill »
The Thermostat is a known failure point for the 3.2
And because it has a mechanism that recirculates the coolant when the engine is cold it can fail and not flow coolant to the radiator.
But the Thermostat is not the leak. If the Thermostat leaks the coolant will be on the Alternator and intake manifold not the serpentine belt
The most common failure is a large coolant hose under the AC compressor
It can be seen in the picture on the left side the belt is almost touching it
Good luck
Paul
pgill
Post by pgill »
This link is discussing that hose
viewtopic.php?t=107618
GreenMagicMan
Thanks so much you two!!
Does this mean the only way to replace that hose (if it is the leak) is to remove the AC pump?
Is that hose the connector to the oil cooler?
'10 XC70 3.2L
pgill
Post by pgill »
I replaced the hose on my LR2 from below.
It is located below the AC compressor.
With the AC compressor removed it is easy to see what you are doing. With it installed it is challenging but not impossible.
I think you will need to remove the tube for the intake
Let us know what you find out
Good luck
Paul
GreenMagicMan
I’m half time at the Volvos location. That and specialty tools (no right mechanic has star tools on hand) and the inaccessibility of this area has all delayed me.
What I did:
Removed airbox, battery and had to leave tray (thanks idiotic hood release cable design), removed the air intake plastic tube BUT only after having pulled the radiator cooling fans to get access.
I then used mirrors and bright LED flashlights for photos and then gave a video a shot. That was the best thing to do.
I just posted a link on youtoobs here:
https://youtube.com/shorts/oETEolBBCQg?feature=shared
I am best guessing this shows that the water outlet plastic 3 say connector has failed (internal o ring?) and dribbling coolant all over with buildup on the engine metal pipe. Thoughts?
It COULD be it is the water pump and it leaked lots (??) on the READ belt which flung it everywhere and FORWARD (?)
But in my experiences almost all leaks move backwards in a moving car and not forwards. I’m sure there can be exceptions. Again, thoughts?
Should I just order this part and replace it (shooting a small parts cannon off) and cross fingers and hope for the best?
Anyone think it still could be the water pump?
Thank you!!
'10 XC70 3.2L
pgill
Post by pgill »
The common failure of that hose is that the rubber will swell and a pin hole leak will form.
It is possible that you have a new failure mode at the O ring
But it isn’t clear from the video
The water pump isn’t very far away and it could be the source for the leak
Good luck
Paul
GreenMagicMan
Thank you.
That phone angle was directly underneath the fitting. The oxidized reddish rusty looking stuff had collected underneath it
'10 XC70 3.2L
pgill
Post by pgill »
Based on that information I would replace the hose and check the top side of the metal pipe to see if it is stained.
If the stain is only on the bottom then it is likely that the O ring inside the hose failed and that is the leak
Good luck
Paul
