While replacing the crank position sensor (CPS) today I noticed a disconnected vacuum (?) line at the air inlet tube nearest the turbo inlet.
Here's before I reconnected it:
and here's after:
I found a vacuum line diagram online that suggests this is the "blue" line, but does anyone know what it does?
I've had the car 12 years and no one has done any work in that area, so who knows how long it's been disconnected. The car ran fine without it connected.
Thanks for any info.
I found this turbo vacuum line disconnected
- Has thanked: 1505 times
- Been thanked: 3818 times
The blue line returns the pressure that isn’t used by the turbo control valve back to the snorkel so no boost pressure is “lost”
If to pops off , the turbo will work fine but you may get a lean code for a vacuum leak if you have a light foot
- DavidE7
- Year and Model: 01-07 V70, S60, XC70
- Has thanked: 53 times
- Been thanked: 62 times
The port for the hose that popped off doesn't have a barb or other retaining feature. It appears that the only way it is retained is with friction and the partial vacuum from the engine and turbo intake through the venturi (diameter reduction) on the intake pipe. A little spring clamp would probably be smart.
The larger hose above it for the carbon canister fuel vapor purge has a small barb on the port . On my three turbo charged vehicles, I found that plastic clip for holding the O2 sensor wire clipped to hold the hose from pulling off the barb. You may want to slide that clip downward to help retain that hose on its port.
I have chased enough false air faults with smoke that I think my cars will each get a spring clamp like the ones at the Turbo Control Valve on that small hose.
David E
2001 Moondust V70 2.4 293,000 miles
2001 Nautic Blue V70 2.4 224,000 miles
2004 Nautic Blue XC70 2.5T 251,000 miles
new: 2004 Black Saphire V70R 193,000 miles
2007 Titanium S60 2.5T 275,000 miles
2007 Magic Blue S60 2.5T 233,000 miles
2007 Silver V70 2.4 200,000 miles
P2 Volvos for every person in my family
vtl
- Year and Model: 2005 XC70
- Has thanked: 114 times
- Been thanked: 606 times
Light foot definitely, since TCV only triggers in high engine loads, when it needs to get rid of of boost quickly. Vacuum leak was probably minimal, fuel trim idn't migrate to out of range yet.
