As financial firms are required to state: "past performance is not indicative of future results".
This time the situation may be different and your changes have not solved the problem.
Try some of the suggestions and tests given here.
2001 s60 !---Totally Stumped on Engine Misfire
- Has thanked: 927 times
- Been thanked: 1000 times
Re: 2001 s60 !---Totally Stumped on Engine Misfire
- Has thanked: 1505 times
- Been thanked: 3818 times
Yep. The misfire algorithm works well for a constant miss, but ot can misread the cylinder if it’s rough running or an occasional miss, in my experiencevtl wrote: ↑28 Jan 2026, 14:18When my #1 blew, I had misfires detected in two cylinders. Forgot which ones, but #1 was not among them.yabadabadoo1026 wrote: ↑28 Jan 2026, 14:15 im no certified mechanic but wouldnt seem to me that would entered into misfire???????--------and why would i check any cylinder other than the one the code is suggesting????? Thanks
You want all cylinders compression tested.
vtl
- Year and Model: 2005 XC70
- Has thanked: 114 times
- Been thanked: 606 times
This was with 0 PSI in #1... Misfire counters were like #2 and #4. Contrary, a dying fuel injector in #3 that was missing the mark sporadically, but it was correctly diagnosed by ECU. Maybe with #1 it goes south because it is the first cylinder in firing order.
