I’m in the process of removing the rear propshaft and viscous coupler to gain the access needed for a variation of the dank drop method for replacing the fuel pump, and have gotten half the propshaft out, but the end in the VC is stuck fast…
Any ideas?
1998 V70XC - In a pickle with the propshaft (Resolved) Topic is solved
- VolvoOwl98
- Year and Model: 1998 V70XC
- Has thanked: 33 times
- Been thanked: 17 times
Lifted 1998 V70XC "Saskia" - Introduction/Continuing Repair Post: viewtopic.php?t=107993
- Chassis number: 475986 (early 1998 chassis dated 01/98)
- Emission code: 4
Learning and growing all the time
- Emission code: 4
- VolvoOwl98
Update: eureka! After an hour of spraying with free-all and using a hammer and chisel at an angle towards the front of the car, it came free!
Will be adding this to a write-up about the fuel pump replacement procedure
- Emission code: 4
- Emission code: 4
- Has thanked: 1611 times
- Been thanked: 4073 times
Those can be tough. It might be seeing daylight for the first time since Goteborg!
- VolvoOwl98
Given the rust, the stubbornness, and the state of the half-disconnected carrier bearing, I believe you are correctabscate wrote: 24 May 2026, 04:30 Those can be tough. It might be seeing daylight for the first time since Goteborg!
- Emission code: 4
- Emission code: 4
- 742 Views
- 11 Replies
- 649 Views
Last post by stickinthemud
- 21 Replies
- 7134 Views
Last post by shiloh51933
- 14 Replies
- 3189 Views
Last post by jvl
- 980 Views
Last post by jcdillin
