850 transmission mystery noise Topic is solved
ToyoToyo
Year and Model: C70 2002
Post by ToyoToyo »
A whine in 1st and 2nd that doesn't get louder is pretty common on these older ATs, worth doing another drain and fill with proper ATF and see if it changes before worrying too much.
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
What brand and type of automatic transmission fluid are you using?
snugani
Year and Model: 1996 855 turbo
Has thanked: 12 times
Been thanked: 3 times
Post by snugani »
I've been using the Volvo dex3 one from fcp, and one drain and fill I did with the Walmart fluid that's supposed to replace dex3. I saw Robert recommended it in one of his vids.
I did a drain and fill after I noticed the noise and there was no change. I wonder if it may have had this noise since I bought it last year, since the old fuel pump was so noisy it may have covered it up. It was shortly after I changed the pump I noticed the transmission noise. Also when I bought it there was no muffler
