Thermostat/Heat Question
Guest
Post by Guest »
My car takes a little longer than normal to heat up and once it does I crank on the heat but the engine temp gauge dips back below the normal temp so my heat goes down a little. Once I turn the heat off after a couple minutes the temp. gets back to normal. I'll cycle it like that a couple of times and then eventually everything is running smoothly. I'm basically just wondering if this a thermostat problem or maybe something more?
Thanks
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1254 times
Post by matthew1 »
Screams 'thermostat' to me.
See my fix procedure here:
https://www.matthewsvolvosite.com/tstat.php
Very easy to do.
Also -> Amazon link
