What parts to pull off a 99 S70 NA for a 98 NA V70 and 99 S70 T5
yanga001
Has thanked: 62 times
Been thanked: 115 times
Post by yanga001 »
I got a 99s70T5 and a 98 V70 NA with a blown motor. I have an option to pick up a crashed 99 S70 for 500 cad with 640k km. The power steering rack feels like butter (nice and smooth) and it has an immaculate u joint which will definitely end up in the V70. It is nautic blue, but some panels are rough so not much transfer.
Interior door cards are great, drivers seat is rough but electronics seem to work. Its a special edition model, just had a timing belt done 20 k km ago. Has a new starter which will end up as a spare, solid radiator which will be a spare.
Im wondering what other things are high on the pull list for reuse. Ill take the coil packs, fuel pump, relays, interior trim pieces, and radios for my 98.
What else would yall add to the list?
2008 S60 2.5T Auto (Sold)
Has thanked: 1609 times
Been thanked: 4065 times
I need the left rear outer turn signal bezel for my 1999 S70
Brake vacuum chamber with sensor
ETM - check label to see what vintage it is
5 coils
sensors on the snorkel under intake manifold
Has thanked: 311 times
Been thanked: 817 times
Brake calipers if they're any good. Same with the strut towers, those are expensive to replace. CV axles if they're not aftermarket trash.
yanga001
Post by yanga001 »
abscate wrote: 29 Jun 2026, 13:38 I need the left rear outer turn signal bezel for my 1999 S70
5 coils
is that drivers side or passenger side for the first one?
yanga001 wrote: 29 Jun 2026, 16:37
5 coils
Drivers side, please. might as well harvest them all - I can pony up the bucks
yanga001
Post by yanga001 »
if i can get it down to you nicely then no charge. i got a second s70 and a third that wont miss that light lol.
I’ve got friends in Buffalo if you ever cross the border for Tim Hortons
