99v 70 Temp and Oil Change
okay, change the oil over the weekend. I went from 5W30 to 5W40 as we've had a lot of heat and the car is getting up in mileage. got in this morning drove A very short distance and when I got back in the car it did not want to start. It started on the second or third try but check engine light will not turn off after driving . ran codes at local auto parts store indicates coolant temp sensor and thermostat. both of these were replaced back in March. any correlation with the oil change? vehicle is running ok and at normal temp. fluids are okay. inspected for any oil leaks after the oil change and a couple of times since including now. Help!
- V50M66
- Year and Model: 1998 V70 AWD
- Has thanked: 26 times
- Been thanked: 94 times
5W-40 Euro spec (ACEA A3/B4) is the correct oil, and what you should be running in these. 5W-30 is too thin, especially in the summer months, if you drive aggressively, or frequently tow or haul things. Your issues are unrelated.
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
1999 Saab 9-3 - daily
2004 XC70 - former workhorse, parted
2005 V50 T5 M66 FWD - former garage queen, sold
2002 S40 1.9T - former daily, rear ended
- Has thanked: 2215 times
- Been thanked: 1853 times
The only engine that I know of in the P80 that is spec's for 5W-40 is my 00 V70R. The others have 10W-30 summer and 5W-30 winter.
But!
If the car is starting to burn the thinner oils, then step up to the 5W-40.
WELL, I just found a Volvo owners manual for a 2000 Volvo and it seems to suggest 5W-40 is the oil that works over all the temperature ranges from -40 to + 104. 5W-30 from -40 to 86F and 10W-30 from around -4 to 104F. Wow, you learn something new every day!
But!
- Has thanked: 1614 times
- Been thanked: 4078 times
We run straight 10W-30 year round in NYC in all our Volvos. We dont get to 104F , ever - and if we did I would stay home or during the peak. Volvo even says brief periods outside the range isnt harmful, so 10W-30 or 40 fine.
These cars are well lubed, cooled, and strong bottom end engines - regular changes of good quality synthetic oil.
- 11 Replies
- 16161 Views
Last post by RossJonnes
- 1388 Views
Last post by FLXC90
- 11 Replies
- 9265 Views
Last post by oragex
- 1338 Views
Last post by richardgengle
- 1522 Views
Last post by mortaay8444
