1998 S70 Keyless Remotes
This topic is in the MVS Volvo Repair Database » 960 AW40 transmission diagnostics
Benji9k
Year and Model:
Post by Benji9k »
I've seen these for sale on Ebay, how do I find out if it's an exact match for my car? Also, is there anyway to program them yourself? The dealership and a couple other places all quoted me at least $90, that's like a 2 hours labor charge. Is it really that hard?
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2654 times
Been thanked: 1248 times
Post by matthew1 »
It's not hard; it's just hard to find out how :-).
Here's what I've found:
Try this: put your key into ignition turn 5 times on and of without starting the engine. When you turn 5-th time do not turn it off, within 5 seconds press any key on your remote. Check maybe it is going to work.
and
1. Turn the ignition key
Also -> Amazon link
Guest
Post by Guest »
I've also done the ignition on and off 5 times and leave it in the on position the 5th time. It's mentioned in the owner's manual and works great. You might want to check the owner's manual in the s70 and it might say how to do it. Also in the 850 the red led light on the dash comes on after the 5th turn of the ignition to let you know it's ready to be programmed. I hope some of this helped.
Guest
Post by Guest »
Does this method work for the 99 S70?
matthew1 wrote:It's not hard; it's just hard to find out how :-).
and
Guest
Post by Guest »
Same question - BUMP
