850R ecu in Turbo model?
Using an R ECU in a Turbo
What, if any, improvements in power would you see if you installed an 850R ecu into an 850 turbo model.. Would this increase the boost to 850R psi as well as fuel compensation? Just curious as to what would I expect if I installed a 96 850R ecu into my 95 turbo... Thanks!
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
Not sure what will happen. You might set some trouble codes if all of the "devices" in your car don't match up with those from the ECU. Maybe others would have a better answer for you.
For anyone interested, I installed my recently acquired used 850r ecu today. Absolutely no error codes whatsoever and it increased the boost from 9 to 14psi instantly. I have not had this car very long so I dont know what else could be attributing to it but that was an easy, cheap plug and play increase in power. Who knows, the car may not start tomorrow but it worked today flawlessly!
MadeInJapan
Good to know...keep us abreast of how the car runs as time goes on.
code-man850
- Year and Model: 855T '96
Is there any follow up on how your car turned out? I'll be plugging my R ecu into my Turbo this afternoon so I'll be reporting the results too. The only thing I looked out for was the year ranges of the 850 (i.e. keep 1994 & 1995's together and 1996 & 1997's together)
'96 855 Turbo
K&N, H&R, Mobile 1
Its a wagon thing...
You wouldn't understand.
K&N, H&R, Mobile 1
bugsbunnies95_850t
- Year and Model: 99 v70R
Well i took the jump. thanks to the fantastic guys on this forum i found a t5r ecu and soon will be pluggin the bad larry into my 850 turbo.. ill keep u all updated on how well or bad it turns out ... keep your hopes high for me!
code-man850
Just to follow up (7 months later) everything worked out great. I did the stage zero before and everything was happy. A great safe mod.
'96 855 Turbo
K&N, H&R, Mobile 1
K&N, H&R, Mobile 1
- 11 Replies
- 3115 Views
Last post by tryingbe
- 4408 Views
Last post by Clemens
- 2412 Views
Last post by shaker_chi
- 1580 Views
Last post by wyoben
- 15 Replies
- 4969 Views
Last post by erikv11
