Volvo 740 GLE 1986 Temperature Control Lever Stuck
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Ferazi
Year and Model: 2003 XC70 2016 XC70
Post by Ferazi »
The temperature control lever will not move from the left (cold) to right, leaving me with no heat or defroster.
Any advice or suggestions would be appreciated.
rmcmighty
Year and Model: 1999 V-70 XC
Post by rmcmighty »
you may have to remove the glove compartment to get at the cable that is attached to the leaver that you are trying to move over to hot !
the cable attaches to another leaver on the heater core and you may be able to move it at that end . Sometimes moisture gets inside and they seize up . you might have to work at it a bit to ease it back and forth and get it free'd up . I used some dry graphite for locks to lube mine up and it works like a champ!
Hope this helps
Kmaniac in California USA
Year and Model:
Post by Kmaniac in California USA »
rmcmighty wrote:you may have to remove the glove compartment to get at the cable that is attached to the leaver that you are trying to move over to hot !
Hope this helps
Let me state for the record that there is NO cable running from the temperature slide to the heater core. The temperature slide is a vacuum switch that controls the vacuum operated heater control valve in the engine compartment on one of the heater hoses. This is how it is in my 1986 740 GLE.
You may have to remove the heater control unit in the dashboard to find the root of your problem.
Chris the "K MANIAC"
1986 740 GLE
(5) 1964 Chrysler 300-K's
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
There are two types of heater for the '86 740: combu has vacuum operation and without combu has cable operation...... and I don't know what combu stands for!!!!
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
rmcmighty
Post by rmcmighty »
billofdurham wrote:There are two types of heater for the '86 740: combu has vacuum operation and without combu has cable operation...... and I don't know what combu stands for!!!!
Bill.
Thanks for the save there Bill :)
rmcmighty
Post by rmcmighty »
Hope this helps
My First Volvo Was an 86 740 GLE. When i bought the Car it had been sitting for 2 years. I had the same problem as this Fellow.
I do believe the Combu equipped cars have the automatic climate control feature like my 88 760 it runs completely on vacuum.
I may be Wrong here but. my perception of the whole set up is: if your whole heater control system uses knobs that you turn then your system should run completely on vacuum.
If the heater controls are leavers that you have to slide then the chances of your system using Cables is very good.
Year and Model:
Well, I never claimed to be an expert, as my knowledge is limited to what I have in the driveway. So, if I spoke out of turn without all the facts, my apologies. This just goes to show that we all learn something knew everyday. :oops:
1986 740 GLE
Ferazi
Post by Ferazi »
I will assume it's cable to start with. Not today, though, as it's only 12 degrees. This vehicle has also been sitting for almost two years...just too bad it wasn't already set on the warmer end.
Thank you to all who replied. I'll let you know how I get on with it.
billofdurham
Chris,
That's what I like about forums and why I devote so much time to them. Until this came up I thought all 700 series heaters had cable controls because mine did. So I have learned something too.
As for "combu" it would certainly seem to be automatic climate control but why don't they just say that?
Bill.
Previously:
Year and Model:
billofdurham wrote:As for "combu" it would certainly seem to be automatic climate control but why don't they just say that?
I DON'T have automatic climate control in my 740, just a heater/air conditioner combination. So maybe there's something more to it. :?
1986 740 GLE
