Cruise Control Shuts off - 2001 S40
1996 - 2004 S40
1996 - 2004 V40
luthersdad
Post by luthersdad »
Has nayone had problems with S40 - 2001 Cruise Control? On a recent trip that was 600 miles each way each time I set the cruise control it worked fine for about 10 miles or less and then just shut off. this happened repeatedly and even after we shut off systrem and car and the restarted it still did this strange action. we did not touch the brake and it was not going up a steep incline, but on flat surface.
It is a bit disconcerting when you are cruising at 65 and all of a sudden you lose speed.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2656 times
Been thanked: 1248 times
Post by matthew1 »
I'd look for cracked or unattached vacuum lines around the engine. On 850s, they're thin white tubes. Don't know about 40s.
Also -> Amazon link
wiv40
Post by wiv40 »
Mine has been replaced twice on my 2000 v40. It's a known problem
hagerfoot
Post by hagerfoot »
I've got a 2002 V40 and have the same problem. Dealer couldn't replicate the problem, but it is still happening. Have to take it back, and I'd like to get this fixed before the warranty expires (in about 8000 miles). Any advice/solutions would be helpful.
Thanks,
Matt
Guest
Post by Guest »
I had this problem when I bought my 2001 S40.
The dealer said there was a broken switch that made the cruise control think the brake was being depressed.
Hope that helps.
