To test the fuel pump relay use a jumper lead, and connect terminals 15 and 87 of the fuel pump relay. That will hot-wire the fuel pump so it runs as soon as the key is on.
I tried this it did not solve my problem but at least it ruled a few things out. You might test the fuel at the rail mine ran around 65psi if I remember right.
850 no spark no fuel
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
Actually, it should be around 45psi.
- 2498 Views
Last post by Roger_850T
- 2873 Views
Last post by ndphotonl
