Glowing Turbo?!
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
940 Beater
Year and Model: 1992 940 Turbo
Glowing Turbo?!
Post by 940 Beater »
Hello,
I'm new to this forum, but have been a Volvo owner for years.
Tonight when I got home I popped the hood on my 1992 940 Turbo to check my air filter, and noticed that turbo was glowing enough to light up the engine compartment. The car has new oil and full coolant. Any thoughts on this would be greatly appreciated.
Thanks
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Was it the turbo or the manifold or both?
You may have a knock sensor problem. The knock sensor could be bad but it is more likely that the connector is the problem. When the ignition control unit detects no input from the sensor the timing is retarded which is the safety from excessive spark knock and this reduces engine power and the delayed timing sends the exhaust gas temperature sky high resulting in the glowing parts.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
940 Beater
Thanks for the reply Bill. I called European Auto, a Volvo specialty shop and the guy I spoke with said that it's normal for the turbo to glow, but I'm not 100% covinced of that. I'll check more in to your suggestion this weekend.
Thanks Again
billofdurham
The turbo does get hot and I have seen them with a slight glow after a hard pushed, non-stop 200+ miles. It was never glowing enough to illuminate the engine compartment.
Bill.
Previously:
940 Beater
billofdurham wrote:The turbo does get hot and I have seen them with a slight glow after a hard pushed, non-stop 200+ miles. It was never glowing enough to illuminate the engine compartment.
Bill.
When I noticed the turbo glowing, it was a short 5 mile ride, but I do drive the car hard. The car has 240k on it so maybe it's starting to feel the miles now. Anyway, it seems to be running ok, I put 250 miles on it today and no problems yet.
