Radiator Fluid smell from air vents
What could be wrong if you have a radiator fluid small coming out of your air vents when the heater is in use or not. I have a 1999 S70.
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
Welcome to MVS.
What you have is a heater core leak. If you lift your driver's side carpet, it is probably damp from where the coolant leaked out.
You can replace this on your own if you take a notion and it's not very difficult. There is a how-to in our repair database with pictures and if you get stuck, we'll walk you through it.
The actual parts will run you between $130 and 180 from an online vendor (heater core and 0-rings)- This is pretty common on our Volvo's once you hit mid 100K miles, unfortunately.
Is it also easy on a '98 V70? The manual I have says you must physically remove the whole dashboard (!) and I'm not hyped on that. This car has always had a mild coolant smell, but hasn't ever dampened the floor mats or lost any coolant to speak of.
I'm hoping you can just remove all that white plastic shrouding under the dash and get to it that way!
- instarx
- Year and Model: XC70 T6 2011
Maybe someone with direct experience can back me up, but I think it is the A/C evaporator core that requires the dash to come out. The heater core is much easier to get to and does not.
2011 XC70 T6 - current
2017 Alfa Romeo Giulia Q2 - Totaled in 2022. Not my fault.
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
2011 XC60 - sold
MadeInJapan
Bingo! the heater core only requires getting under the radio/climate unit stack in the center console...much easier to deal with.instarx wrote:Maybe someone with direct experience can back me up, but I think it is the A/C evaporator core that requires the dash to come out. The heater core is much easier to get to and does not.
Hi there, I just had my heater coil replaced. It cost me $500. I don't know if they took the dash board out. I was told by other mechanics that they would have to remove dash so they can replace it.
I have 2000 XC70 wagon.
ciao for now
nunu
ciao for now
nunu
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 73 times
I have the exact same car as you, nuncpf. I replaced my heater core last weekend, cost me $120 for the core and I did it myself. It was a bit of a pain working in the tight spots and I had to undo and re-attach the new one once, but it was worth it to save almost $400!
You have to clamp off the heater hoses in the engine compartment, pull the carpets back, remove the plastic shields (slides out, super easy), take out the screws around seam of the heater core box, undo the main screw attaching the core to the pipes, wiggle out the old one (some coolant drains here, have a plastic bag), replace the core and put it in the way you took it out. Took me about 5 hours, but this was my first decent car surgery and I was taking it slow. If I had to do it again, I would guess I could do it in under an hour!
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- 1896 Views
Last post by jblackburn
- 342 Views
Last post by IG-88A
