'87 240 Wagon Blinkers Stopped Working
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
washfit
Year and Model: 1987 240
Post by washfit »
Any ideas? The blinkers stopped working - I just get kind of a weak, buzzing vibration from the flasher relay. The 4-way flashers work fine, and every now and then the blinks WILL work for a little bit. I replaced the relay - same problem. Swapped in a spare instrument cluster - same problem. Anyone got a wiring diagram I can look at?
Thanks!
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Have you checked the indicator switch? It may pay to treat the contacts with a contact cleaner. Over 22 years they will have a fair coating of dust, tarnish and other undesirables.
This wiring diagram does not show the actual lights but they are a straight cable run from the switch. If you need the 'other ends' just ask.
240 indicator wiring diagram.pdf
(726.02 KiB) Downloaded 291 times
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
kluts
Year and Model:
Post by kluts »
Hi, may I join in? I have an 86, posted earlier about this. Four-Way flashers and bulbs work. Turn signals are stone dead.
Replaced the turn signal indicator switch. No change, both units flash the headlights just fine but no turn signal action. Replaced the relay. No change. Checked the fuses. No change.
:( :shock:
Looking for ideas....
Always do right. It will satisfy some people and astonish the rest--- Twain
billofdurham
Anybody can join in. Have you checked to see that 12 volts is reaching the switch?
Bill.
Previously:
audiochuck
Year and Model: 87 740 wagon
Post by audiochuck »
I have an 87 740 Wagon with the same problem. Driving yesterday and turn signal blinkers stopped working along with power windows. Thank god the windows were closed because it was raining. Main thing is the turn signal blinkers. Installed new fuse #15 but still no blinkers. Should I replace blinker module? Please HELP!!!
billofdurham
audiochuck, welcome to Matthew's Volvo Site.
Do your hazard lights work or is it just the turn signals you have lost?
Bill.
Previously:
