V70 2005 with clunking front end
ghersey
Year and Model: V70 2005
Post by ghersey »
I have been getting a subtle clunking noise from the front end. It occurs over bumps and rough roads. It's not horrible, for instance with the radio on you don't hear it. However it does not sound normal.
When I had the car in a few weeks ago I had the dealer take a look. Apparently they could find nothing loose.
The noise is still there. Any ideas of what could be clunking?
Thanks!
Mandrake
Year and Model: 01 S 60 T5 146k mi
Post by Mandrake »
Not sure if this helps at all but with my 2001 S60 I had a similar problem. It was more of a rattle then a clunking noise. Which turned out to be bad anti sway bar links.
velorider
Year and Model: 2005 S60 T5
Has thanked: 2 times
Been thanked: 26 times
Post by velorider »
I've heard the spring seats could cause similar noises. IPDUSA sells replacement spring seats. There product page also describes similar sound that you are describing.
http://www.ipdusa.com/Volvo-S60/Suspens ... -404-4251/
ghersey
Post by ghersey »
Thanks for the ideas. The car goes in next week to switch out the winter tires. I'll request they check both of these.
