The manual says that it isn't necessary??? I've never heard of such a thing.
What do you all think? How often do you flush your cooling system?
Coolant flush, how often? 2005 S80 2.5T
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
I would flush it before 50K miles and then get on a 30~40K maintenance schedule for the flush- great prevention to say the least. All of those transmission that have bit the dust that I know of are ones whose owner followed the Volvo company line that it is a closed system and never needs flushing.
MadeInJapan
Oops, sorry...actually what I said is true about the transmission but for the coolant, I would flush every other year.
Thanks for all your help.
BTW, in the booklet it says that Volvo doesn't approve the use of recycled antifreeze. Do you think it's that big of a deal to use recycled antifreeze? I wonder if Volvo dealers use new Volvo antifreeze.
MadeInJapan
On all of my Volvo's I use Ethylene Glycol based antifreeze and try to stay away from those with too many additives. Zerex makes a good one for that... All should be that fluorescent green stuff and on the bottle it will say 'safe for aluminum," etc. That said, on our V70, I went ahead and splurged for the actual Volvo coolant. Just flush water through after engine is hot... after you pull the drain plug about 1/2 of the coolant/water will come out...I usually add distilled water, warm the engine up and drain again, twice....then shut off the petcock and fill completely w/ the 1 gallon of coolant and then top off w/ distilled water. In the end, you're about at 50/50 mixture with the Volvo coolant and the distilled water. Good luck!
