2000 T6 Serpentine belt
wolfspiritky
Year and Model:
Post by wolfspiritky »
I need to swap alternators on my 2000 T6. I was unable to find any info in the help data base. Can someone post a link. I'm not even sure how to loosen the tensioner to remove the belt.
THANKS
00 S80 T6
97 850R
94 850 GLT-Totaled!
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Hopefully this will help:
2000 S80 T6 Aux Belt Tensioner.pdf
(121.29 KiB) Downloaded 272 times
vegasjetskier
Year and Model: 2010 Toyota Prius
Been thanked: 6 times
Post by vegasjetskier »
Dude, I'm afraid you've got your work cut out for you. This is in 6 parts because my VADIS will only print the screen, not the topic.
S80AuxBeltChange-1.pdf
(115.85 KiB) Downloaded 232 times
S80AuxBeltChange-2.pdf
(126.94 KiB) Downloaded 161 times
S80AuxBeltChange-3.pdf
(113.33 KiB) Downloaded 228 times
S80AlternatorReplacement-1.pdf
(118.03 KiB) Downloaded 161 times
S80AlternatorReplacement-2.pdf
(129.27 KiB) Downloaded 207 times
S80AlternatorReplacement-3.pdf
(120.67 KiB) Downloaded 134 times
vegasjetskier
Hey, MIJ, how do you get your VADIS to print the whole topic to a PDF? Mine will only do a "print screen," so I have to do each topic in several parts, which is a real PITA. Thanks.
vegasjetskier
Wolf, here's the procedure to remove the power steering pump:
S80PowerSteeringPumpReplacement.pdf
(185.76 KiB) Downloaded 219 times
MadeInJapan
I use a program called Win2Pdf...works very well!
vegasjetskier
MadeInJapan wrote:I use a program called Win2Pdf...works very well!
Me too. But the VADIS wouldn't print the whole topic. Then the last few times I tried it it started working all by itself. I guess the Volvo software is about as reliable as my Volvo car. :D
MadeInJapan
I don't know...my copy works fine ever time. Sometimes though when I switch over to my real printer, it still wants to make a pdf file. Rebooting the computer fixes this. Otherwise, I'm not able to print to pdf any of the one page parts diagrams so I just use the "Print Screen" key and PaintShop to make a jpg file for those.
wolfspiritky
Year and Model:
Done deal......just needed to be sure how the tensioner worked!!
Saved my a$$ AGAIN Dave!
Thanks Buddy!!
00 S80 T6
97 850R
94 850 GLT-Totaled!
