Error Code P0012, V70-II (P26) Topic is solved
Guest
Post by Guest »
Hi,
I checked my car using the "vehicle explorer" at the OBD-2 Interface.
One error was found
"P0012 Intake Camshaft A Position Timing is over retarded, received from Engine Controller adress $12"
I deleted the message an it did not turn up again.
Any idea what is behind this message?
Thanks
V70-II (P26), model 2002, delivered Nov 2001, 103 kW, 65.000 km
dosbricks
Post by dosbricks »
Was this investigation prompted by a check engine light?
pike105
Year and Model:
Post by pike105 »
thanks,
no check engine light, however, a yellow symbol (error in emission system) showed up for a couple of hours last august .
dosbricks
Post by dosbricks »
If it has been fine since Aug. with no CE light, you might want to just consider it a "random event".
