740 Turbo Wagon 1992 Catalytic Converter overpowering Turbo
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
AthenaJade
Year and Model: 1992 740 Turbo Wagon
Post by AthenaJade »
Well here's the deal, my check engine light came on last week, I was supposed to get it checked by my mechanic on Sunday, but things came up. So, when I went into get my oil changed I asked them to check it for me. First the guy irritated me by asking me..."what it's been on for like a month?" then looked at me funny when I said no just since last week. Anyways, he checked it and said that the cat is overpowering the turbo and if I don't get it fixed the engine will go kablooie :( He said that there's one way to fix it that will cost $250 then if that doesn't work they'll have to do something else that will cost another $600, but they'll put the $250 onto that so, in reality to fix it, it would be $575, but then on top of that something about California regulations (I live in Arizona) making it so, they'd have to tack on another $400, for something, I have no clue what, making it $975. I didn't get anything done yet because, my boyfriend called our mechanic, who will do the work for free, (well mostly free I make he and his wife food, and babysit their kids sometimes ha! I have the cheapest mechanic ever! Yes, he is a legit mechanic, he has been working in shops for the last 20 years), and he's going to take a look at it on Sunday. My question is, where can I figure out what actually needs to be done, so I can find out the parts I need to get, because I know the shop I went to for the oil change jacked it up for labor and what not, I just want to know what the part is and the cost, because it is driving me nuts not knowing how much the shop is possibly trying to screw me over. Anyways if anyone can help me out it would be greatly appreciated.
Thanks
MasterBlaster
Year and Model: 1990 740GL
Post by MasterBlaster »
No problem (yet)... your car has a built-in way to help you figure out what's wrong with it.
Please don't go there anymore. The guy is an idiot, and has no idea what he's talking about.
My question is, where can I figure out what actually needs to be done, so I can find out the parts I need to get..........I just want to know what the part is and the cost, because it is driving me nuts not knowing how much the shop is possibly trying to screw me over.
For every penny they can.
Read the answer on this page:
http://autorepair.about.com/library/a/1g/bl661g.htm
It's for a different problem, but it explains fairly clearly how to read your error codes. Even if your particular code isn't listed there, at least it will give us somewhere to start. The "diagnostic socket" is a small, black plastic box under your hood. The "selector cable" is just a short jumper wire that's attached to the box, and plugged into the lid for storage. Some models have two boxes, some only one. If you have two, use the one marked "A".
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
AthenaJade, welcome to Matthew's Volvo Site.
I agree with everything MasterBlaster has said. Many problems can be detected using the on-board diagnostics, something that the rip off merchants you saw obviously don't know.
The link you have for the diagnostic unit is good although basic as the box has more functions to assist in the repairs. I would disagree about
Remember, all vehicles except California market cars can store only three codes.
After the repairs, the vehicle must be driven in order to find and set new codes.
All of my Volvo literature has this information:
740 diagnostic output1.pdf
(39.18 KiB) Downloaded 128 times
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
AthenaJade
I get that it needs to be checked again, I'm having that done tomorrow by a mechanic that I trust and has done all the repairs on my car, my question was about what the mechanic who told me that the Catalytic Converter is overpowering the Turbo. The cost to repair it.
vegasjetskier
Year and Model: 2010 Toyota Prius
Been thanked: 6 times
Post by vegasjetskier »
The cat cannot "overpower" the turbo. However, the cat can get clogged, which will cause your engine to run poorly. The cost to replace the cat is several hundred dollars. But before you do that, have the codes checked as the others have suggested. I think you are correct that the mechanic was trying to rip you off. Go to a shop that knows Volvos or a Volvo dealer.
Oh, and if you live in AZ you do not have to comply with CA emissions rules.
