What kind of battery??
mrreilly
Year and Model: 1998 Volvo S70 GLT
Post by mrreilly »
When I bought my car it came with a cheap replacement battery and I think it's starting to go. What brand of battery should I go with?
Another quick question. I might replace my speakers later this summer. What size are the speakers throughout the car and what kind of speakers should I look into?
Thanks!
1998 Volvo S70 GLT Black/Tan
Approx. 173,000 3/27/2010
My major repairs:
Timing Belt, Left&Right Control Arms, Tie-rod ends, Lower Engine Mount, Engine Stabilizer Mount, IPD Sway Bar Links, Brakes , Head Gasket, PCV System, Turbo Rebuild, and more
volvomileage
Year and Model:
Post by volvomileage »
good afternoon mrreilly
for the battery i chose a higher quality battery from a nationwide chain, i personaly look for the highest cold crank amps i beleive it has to be above 600 cca (i live in a cold to very cold climate 4 to 5 months in the year) up to now no complaints...
as for speakers these are the specs for the 850 model
front doors
6-1/2"
rear speakers
6" x 9"
regards
volvo 850 95 sedan non/turbo 185 k
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
As far as speakers go I couldn't get 6x9s to fit into my OEM housings. Here is how I did mine.
https://www.matthewsvolvosite.com/forums ... php?t=8402
Matty Moo
Year and Model: 850, 1996
Been thanked: 30 times
Post by Matty Moo »
As much as I despise Wal-Mart, I did buy my battery there.
Group 48, which is bigger than the stock group 47 for $66. something like 660cca. that's half the price sears wants for the same size.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
Marco
Year and Model: V70 XC, 1998
Post by Marco »
Group 48 is a good suggestion. I bought an Autocraft group 48 (700 cca) and have had no problems. The group 48 fit with no adjustments needed.
-- Marco
  • Volvo wagon
    Chevy pickup
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
I bought a group 47 Bosch from PepBoys last summer while they were on sale and got a $10 rebate to boot!
mrreilly
Post by mrreilly »
Thanks for all the advice! I'll look into a 47 group battery. I'll probably shoot for one of the well known brands as long as it doesn't cost too much. Thanks for the speaker info as well I may take care of those later this summer.
My major repairs:
dan2286
Year and Model: 94 850 N/A 5 Spd.
Post by dan2286 »
Keep in mind that a lot of the batteries are made by the same company and just have different names put on them. I have a Napa Gold in mine and it says it was replaced in '02 and it is still doing good. I think how long it lasts really depends on how it is maintained and if it gets drained all the time by leaving lights on or having the radio on with the engine off. Always make sure the water in the cells is kept full and keep it clean.
kelvin6
Year and Model:
Post by kelvin6 »
I have a Autolite battery from Kragen (OReilly's) and this battery is actually seeping acid from the side seams and even one of the vent ports which is covered with a rubber plug is getting pushed out (the other vent, i placed a vac hose on it (leading to the ground) so it doesn't vent into the engine bay).
I took it in for warranty replacement, and they denied the warranty (even though the battery was 9 months old), because they ran it through their 'tester' and it said the battery was good. According to their store policy they cannot accept a battery back if it rates as good by their checker.
I need to go back there when I find the time to talk to their manager, and discuss that policy. Its down right dangerous to have that battery with it leaking acid (streaking trails of it along the side of the battery). The battery could potentially leak acid that corodes electrical wiring and because its near the headlight, if it takes out my headlights at night and I get into a accident....
I'm going off on a tangent here, but simply put, I'm not going to buy another battery from them again. I could still get a new battery if I suck out some the acid inside, then there is no way its gonna register as a 'good' battery....
1998 Volvo S70 T5 Auto
1995 Volvo 850 GLT <- RIP
db130
Year and Model: 2002 V70 T5
Post by db130 »
in most cases, there is no price difference between a group 47 and a group 48 battery, except that you end up with roughly 15% extra cold cranking amps when you go for the group 48 battery.... so if they cost the same and they both fit in the factory battery tray, why not go for the group 48 battery?
2002 V70 T5 169k
2002 V70 NA 249k
2006 Mini Cooper S 90k
