960 1996 Bad noise and vibration from climate control blower
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
doc2x
Year and Model:
Post by doc2x »
There's NO paper/plastic visible in the intake opening. The trap door doesn't open when the blower runs, but I can push it open with a screwdriver. I read the illustrated instructions on how to remove the blower from other models. Will I set off the passenger airbag if I use the same procedure on my '96 960? Thanks.
DanR
Year and Model:
Post by DanR »
You may not have to mess with air bag system at all, at least on my '94 one does not. You remove the lower cover on the dash under the glove box and you will gain access to the blower motor. Disconnect the negative battery cable first though, make sure you have the code to activate the radio when you are done.
It does sound as though the bearings may be shot in your blower motor.
DanR '94 964 343,000 miles (109,000 on the new engine)
vegasjetskier
Year and Model: 2010 Toyota Prius
Been thanked: 6 times
Post by vegasjetskier »
960BlowerMotorReplacement1996.pdf
(78.72 KiB) Downloaded 108 times
