850 Not starting, no spark . . .
The other day my girlfriend and i were going to pick up a couch with my (fairly new to me) '94 850 turbo wagon, turned the key and it would only turn over but not fire. I popped out a spark plug, had her crank it over and alas there seemed to be no visible spark. So today i was able to get over to autozone to rent an engine scanner but the only thing it threw back at me was the P0133 o2 sensor code and i don't think that is the problem. Also, i'm pretty certain it isn't a fuel issue because it won't fire with ether on the air filter and when i pulled the fuel rail apart gas definitely sprayed out. Does this sound like something anyone else has experienced and maybe could lend some advice?
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
What comes to mind is the cam position sensor (without the car turning over, this code is typically not set but it will keep the car from turning over), or bad ignition wires, rotor, cap or the one single wire from the ignition coil to the rotor or the ignition coil itself.
alright, so it's been a couple weeks and have replaced plugs, wires, rotor, and rotor cap. I took the ignition coil to a shop, they tested it and said it was performing within the acceptable range. The problem still persists and i'm almost positive the CPS is not at fault. From what i have read they will cause stalling and hesitation at acceleration before actually failing completely. this didn't happen to me. ran fine one night and then the next morning there was nothing. the guy i bought the vehicle from this winter was selling it because it wouldn't start in the morning on cold days and needed to be jumped; then would run all day. that happened to me like once but figured it was just a dying battery. this is so aggravating! i fear i'm close to taking it to a shop
confused_al
- Year and Model: 1996 TLA wagon
Where did you get that idea? When my CPS went south, it was exactly "turned the key and it would only turn over but not fire" with no sparks. Nor did I experience any stalling prior to that.nmotzing wrote:... The problem still persists and i'm almost positive the CPS is not at fault. From what i have read they will cause stalling and hesitation at acceleration before actually failing completely.
Having said that, you might also want check your fuel pump relay and/or fuel pump by checking the fuel pressure at "no start".
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
MadeInJapan
No- that thing doesn't change the timing in any way... Did you buy a new one or a used one?
brand new. when it started i was jumping off of a 4.0L suv. could the higher amperage of that system make a difference? since i have jumped off of two different 4 cyl that haven't done it. might my battery be getting ruined/going bad?
MadeInJapan
It's very possible- can you get a hold of a trickle charger?
first off, thanks for all your help. this has been so frustrating but i'm not the kind of person that outsources my auto repairs.
i bought a trickle charger yesterday and let the battery top off overnight. didn't make any difference. i know it is still an electrical problem but can't figure out why it would start once but now--without doing anything the vehicle--won't. maybe i should just torch it for the insurance money?
- 2469 Views
Last post by Roger_850T
- 2848 Views
Last post by ndphotonl
