What might be the cause of my left front wheel making a clicking sound when they are turned full left? Any info is appreciated.
Thanks in advance.
Front Wheel Clicking
the most probably problem here is the cv joint is worn out. truning the wheel full lock to the left defeinately indicates that its a cv joint. try and look to pruchasing a haynes manual for your car. its worth its weight in gold, mine is. this would also tel you how to diagnois your fault.
good luck Pete
good luck Pete
- 822 Views
Last post by jbeebo
- 595 Views
Last post by timmybdaddyof3
