740 GL 1989 Acceleration problems
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
msackmann
Year and Model: 1989 740 GL
Post by msackmann »
Hi all, wondering if anyone has any ideas about what might be wrong with my car. Car starts fine and idles great, but when put in drive the car will barely accelerate. And the RPMs barely creep over 1.5. I have changed the ATF, and checked the gear selector. Cleaned the MAF with MAF cleaner. All these didn't help. I am thinking maybe its the MAF because when i unhook it from the air filter, the car accelerates much better (but will not shift). I also unhooked just the electric plug from it and car stalled immediately when in drive. So maybe the MAF is broken and not just dirty? I also cleaned the throttle body yesterday but haven't put it back on. I have not checked for vacuum leaks yet, which is a possibility. Could the timing be bad? I originally thought it was transmission problems, but now I'm thinking its something else. Any help would be greatly appreciated.
thanks,
matt
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
There is mounting evidence that a dirty MAF sensor can cause gearbox malfunctions, such as reported incorrect ratio errors, loss of 4th gear or torque converter clutch (TCC) operation, even on gearboxes recently overhauled at great expense. When you unplugged the MAF the car would drop into limp home mode thus eliminating some of the gear changes.
As you have cleaned the MAF without success it seems that a replacement is called for.
Having cleaned the throttle body you may notice a rise in the idle speed. This can be remedied quite easily.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
msackmann
Post by msackmann »
Thanks, Bill for your respoonse. It actually was the throttle body. When I hooked it up after cleaning it she ran like new. Well...more like a 20 year old car, but good enough for me.
Thanks again,
matt
billofdurham
Thank you for the update.
20 year old cars are often less bother than 20 day old things and easier to work on!!!
Bill.
Previously:
