960 sedan 1997 65000mi check engine light on and runs rough
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
jgb
Year and Model:
Post by jgb »
This is my sons car and as he is driving he called to say check engine light on and car running rough. He pulled into a parking lot and waited for me. When I got there noticed engine running rough like is not running on all cylinders. I took it to autozone to have them try to pull code. they gave me a misfire on # 3 cylinder. I was going to pull coil and have it checked. Any other suggestions?check engine
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
That sounds like a good place to start...coil, plug itself, wires, dist cap, etc. espeically if it's only on that cylinder. I know nothing about 960's, but there should only be one ignition coil for all the cylinders, at least until it became the S90.
'98 S70 T5
2016 Chevy Cruze Premier
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Not so. It has 6 individual coils.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
jgb
Year and Model:
Post by jgb »
You re correct. There are 6 coils and number 3 was not firing. I replaced it and the car runs great now. I just need to figure out how to get the check engine light out.
jblackburn
Sorry about that! That's why I stick to the 850 section haha. Just drop by an auto parts store and they should let you use a code reader that you can use to clear the codes. Or you can disconnect the battery for about 10 minutes. Just make sure you have your radio code.
'98 S70 T5
