Not a whine but an actual rattle
Hello all,
I'm hearing a strange noise coming from my car nad wanted to know if you all could help me.
Ok I know my cv axles are deader than jimmy hoffa but i dont think this is coming from them, correct me if i'm wrong.
The car idles fine and accelerates just like it should but i keep hearing this strange rattle coming from under the hood. It's noticeable because i think the sound it bouncing off the ground.
My friend is scaring me saying it may be teh bottom end of the engine spinning its last few spins.
It's hard to actually describe teh sound but if you were to have a childs rattle and put it under the car thats what it sounds like. No i havent run over any babies...today.
If this sounds like anything you've experienced please let me know.
High Pitched Rattle Coming From Front Under Accel....
ANIGAV Inc.
- Year and Model: 96 850 t5
1996 - 850 turbo
- Year and Model: Many Volvos
- Been thanked: 76 times
Check the heat shield above the catalytic converter. It is in that general area and it gets very noisy if it gets loose.
ANIGAV Inc.
wow, i didnt think of that.
thanks
thanks
1996 - 850 turbo
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
I had a really bad metallic rattle in the car. It started as an intermittent noise that eventually ended up being at nearly every speed. Turned out to be the drive shaft dying.
But definitely start with the less expensive stuff!
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
I had a nasty rattle once under hard acceleration in my old 850. The mechanic, once the car stopped working, explained the reason for the rattle was the same reason for the smoke and the fact I need a new engine. - The head gasket had gone and taken the alloy head with it.
ANIGAV Inc.
I see you have awd so i can kinda breathe easy. Although My cv axles are done, i'm replacing them on friday and will cross my fingersecbsykes wrote:I had a really bad metallic rattle in the car. It started as an intermittent noise that eventually ended up being at nearly every speed. Turned out to be the drive shaft dying.
:gulp: i'm getting smoke from my exhaust and dip stick but an chalking up to my PCV needing to be replaced, also doing this friday.Jesus wrote:I had a nasty rattle once under hard acceleration in my old 850. The mechanic, once the car stopped working, explained the reason for the rattle was the same reason for the smoke and the fact I need a new engine. - The head gasket had gone and taken the alloy head with it.
I'm getting nervous now. She has 186,xxx on her and oil changes have been done like clock work. I bought it from a volvo mechanic at a volvo dealership so i would assume it was in halfway decent shape when i got it.
I'll keep you all posted.
1996 - 850 turbo
The smoke wasn't from the exhaust it was from out of the wheel arches and round the bonnet once blown!ANIGAV Inc. wrote:
My post was tongue in cheek, sorry for worrying you. That is actually what happened to me, but in the space of about 20 seconds not a period of days or anything. I just got some horrible rattley metallic noises, a loss of power then 850 death + much smoke.
It had 136k on the clock, but the mechanic had some how missed the blowing gasket when i went in to find a water leak. The writing was on the wall when he couldn't find the leak and sent me on my way with a new radiator cap. (Mine had blown off!)
Brutus Maximus
- Year and Model: 94 850 Wagon
It could be the fuel/air mixture detonating (aka pinging) in the cylinders. Detonation can sound exactly like a baby's rattle, and it usually happens only during acceleration. Have you recently changed brands of gasoline? I'd try filling the tank with some 91-octane premium, or at least adding a dose of octane booster to the tank. If that doesn't quiet the noise, you'll only be out a few bucks. If it does stop the noise, you need to determine why it started detonating. You could have a bad knock sensor, or you could have excessive carbon deposits in the combustion chamber.
Either way, don't let it go on for an extended period, or it can blow a hole right through the piston crown. Then you'd be in a world of hurt.
Good luck, and let us know what you find out!
Here are some links with additional information on detonation:
http://www.tuninglinx.com/html/detonation.html
http://www.motorcycle.com/how-to/wrench ... -3420.html
http://www.kb-silvolite.com/feature.php ... ction=read
ANIGAV Inc.
I've been using 87 from Wawa for the past few months. I'm at a half tank so i'll grab an octane booster on my way to school.FCPGroton wrote:What kind of gas are you running in it? I hope it is not the engine knocking.
Phew thanks for that clearing that up. No water leaks so far.Jesus wrote: The smoke wasn't from the exhaust it was from out of the wheel arches and round the bonnet once blown!
Thank you Thank you Thank you. Going to get the booster in a few. It's possible I have a bad knock sensor, the car has a few years on it. How do I check the sensor?Brutus Maximus wrote:It could be the fuel/air mixture detonating (aka pinging) in the cylinders. Detonation can sound exactly like a baby's rattle, and it usually happens only during acceleration. Have you recently changed brands of gasoline? I'd try filling the tank with some 91-octane premium, or at least adding a dose of octane booster to the tank. If that doesn't quiet the noise, you'll only be out a few bucks. If it does stop the noise, you need to determine why it started detonating. You could have a bad knock sensor, or you could have excessive carbon deposits in the combustion chamber.
ANd as far as excessive carbon deposits wouldnt that get cleared up by using seafoam?
1996 - 850 turbo
- 11 Replies
- 2253 Views
Last post by Sommerfeldt
- 817 Views
Last post by APCalifornia
- 9 Replies
- 1595 Views
Last post by Marilyn99
- 1499 Views
Last post by MadeInJapan
- 902 Views
Last post by 850 LPT
