Get your car and top it with Sunoco.Drive it and check the mileage, then get you wawa gas and run the same trip.Check your mileage.
The fuel additives are the only thing that make up the differace in brands of gas.
But the additives will determine the way the engine performs.
For what a can of octane booster will cost you can buy some real gas.
High Pitched Rattle Coming From Front Under Accel....
ANIGAV Inc.
- Year and Model: 96 850 t5
Closest sunoco is 30 mins away, we have bp, exxon, shell close by
1996 - 850 turbo
ANIGAV Inc.
Ok so I spent $18 on 104+ octane booster and fuel injector cleaner then another $22 on 8 gallons of premium from Exxon. Sadly the sound is still there and exoon has my money. Weak.
When i got home it was raining so i couldn't get under the car to tap the cat cover but i popped the hood and revved it (tb cover is off) while i searched out the sound.
Took me a while but I isolated it to the sound to the back side of the engine...somewhere around the turbo. I tapped on the shield with my flashlight but it seemed solid.
Think i could be hearing BAD shaft play?
1996 - 850 turbo
ANIGAV Inc.
bought an auto stethoscope today and tried it out. Still nothign concrete but its possible the sound may be coming from the tensioner.
Thoughts?
Thoughts?
1996 - 850 turbo
- Year and Model: Many Volvos
- Been thanked: 76 times
Which tensioner?
The serpentine belt tensioner will cause you anguish since when it gives up most of the idiot lights will suddenly illuminate and the AC will no longer work but it will cause no real harm. The timing belt tensioner or the timing belt tensioner roller, on the other hand, will cause much more anguish if it fails since it essentially means "Game Over" for the engine if it fails.
FCPEURO
- Year and Model: 2006 XC90 V8
- Been thanked: 19 times
+1, The difference is life or death for the engine. If it ends up being the Timing Belt tensioner, get it fixed ASAP.Ozark Lee wrote:Which tensioner?
ANIGAV Inc.
I'm thinking its the one at the top of the engine. You can see it move, near the thermostat.
Better to be safe and order it now.
1996 - 850 turbo
You should be able to just buy the roller part of that if the tensioner is otherwise holding the belt taught.
ANIGAV Inc.
Geez its been forever but hopefully someone else can use this.
Don't forget to tighten both screws holding that large metal "shim" on the side/bottom of the a/c compressor.
It will rattle under acceleration and drive you crazy
1996 - 850 turbo
- 11 Replies
- 2254 Views
Last post by Sommerfeldt
- 818 Views
Last post by APCalifornia
- 9 Replies
- 1595 Views
Last post by Marilyn99
- 1499 Views
Last post by MadeInJapan
- 902 Views
Last post by 850 LPT
