Advice on buying a XC
hammertime
Year and Model: '04 XC90, '07 XC70
Post by hammertime »
I have owned a '96 850 wagon for almost a year now and I love it so much that I want to add another to the family fleet. I am looking at a '98 V70 XC. I've learned a lot about the 850 in the past year but know nothing about the all wheel drive systems. Is there anything I should be looking for/ looking out for when I inspect the car?
'04 XC90
'07 XC70
Zamboni Model 545 (my work vehicle)
Prev. '68 142, '96 850 GLT Sportswagon, '98 V70 AWD, '98 S70 T5, '00 V70 XC
first car ever owned: '74 BMW 2002tii
850wagon
Year and Model: 1996 850 wagon
Post by 850wagon »
only big thing you should look for with these is the awd unit. unlike its later models xc70. the 98 had a gear based awd which was very touchy. its highly recommended that all tires are the same diameter. not just tire size(ex 195/65/15) but all tires need to be same tread depth or it could potentionly destroy the angel gear.
FCPEURO
Year and Model: 2006 XC90 V8
Been thanked: 19 times
Post by FCPEURO »
I had a 98 XC70 and I would never get another one. The angle gear is so touchy that mine blew out just driving 10 miles on the spare. If you are looking for an XC, I would go with something that is at least the second generation. Look for something 2003 on.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2653 times
Been thanked: 1247 times
Post by matthew1 »
Look for more on this subject in the Volvo Repair Database.
There are two threads "Front Driveshaft Removal V70 XC" and "Front Driveshaft Remove + Replace" that both have the now-common fix to the broken angle gear syndrome: removing the driveshaft and making older XC's into just FWD cars.
Also -> Amazon link
iselloil
Year and Model: 1999 V70 XC AWD
Post by iselloil »
I love mine,but as stated in other post,you better check it out well. Make sure all of the tires are the same size and make.Check the turbo for leaks around the bottom of the turbo area,check cv boots,and make sure the trans fluid is clean.
Any shutter in the trans beware!
1999 V70 XC
1999 V70 under constuction,or
destruction from previous owner
Mobil 1
K & N Filters
Ceramic brakes
hammertime
Thanks for all the input. I rejected the car for a multitude of reasons, your advice being the final nail in the coffin. I'm in no hurry so I'll just keep looking and waiting for the right car to come along.
'04 XC90
'07 XC70
instarx
Year and Model: XC70 T6 2011
Post by instarx »
You know, I see a lot of these still on the road so they can't be all that horrible. Like you I read about them and asked for advice here and on other BBs (and got about the same comments as above) so I was very concerned about reliability. I've had mine for 19 months now and have spend a grand total of $161 in repairs (bad ignition coil). Even though I'm about to spend another $150 for a new heater core, that's not bad at all for a 9 year old car with 145,000 miles. It's been a great car and very reliable.
Things I'd look for:
  • Are all the tires the same?
  • Do you smell any coolant when you start it and turn the heater on? If so you'll need a heater core soon.
  • Does the tachometer hunt when it is at idle? May indicate a failing ETM.
2011 XC70 T6 - current
2017 Alfa Romeo Giulia Q2 - Totaled in 2022. Not my fault.
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
