I HAVE A 95 850 WAGON GLT...I NEED TO REPLACE THE BOTH LEFT DOOR MOULDINGS. WHAT DOES IT ENTAIL?
ALSO, THE TIMING BELT WAS DONE AT 70K ACCORDING TO THE STICKER.
I JUST BOUGHT THE CAR WITH 148K ON IT. I DONT KNOW IF THE BELT WAS DONE AT 140K(NO RECORDS). I'M GOING TO PULL THE COVER AND INSPECT THE BELT? WHAT DO I LOOK FOR. I KNOW WITH SERPENTINE BELTS THEY SAY REPLACE IF THERE ARE CRACKS EVERY 1 INCH OR SO.
BODY MOULDING-----TIMING BELT
I would go ahead and just replace the timing belt to be sure. It is a simple project and the belt is only about $25. It is alot easier then rebuilding the engine after timing belt failure! Timing belts are difficult to inspect as some problems with them may not be readily visible.
2004 XC70
2005 S60 2.5T AWD (gone)
1996 850 GLT Wagon in Blue (gone)
1996 850 GLT Wagon in Green (gone)
