Volvo 240 1989 Transmission Problems
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Cassman500
Year and Model: 850, 95
Post by Cassman500 »
i recently bought a volvo 240 with 214,000 miles on it, relatively low for a Volvo of that age. quickly i noticed that it was taking a very long time for it to shift from 2nd to 3rd gear, reving the engine fairly high, and i have to take my foot off the accelerator for it to shift. some times even 1st to 2nd. once in a while when i shift into D i can hear the transmission making a sort of crunch noise, not terriable but definatlly there. I know it is a broad description but im just curious as to the check list for figuring out what needs to be done. if it is simple enough as changing and flushing the transmission fluid? Thanks a lot, Andrew
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Check the transmission fluid for quantity and for colour/smell.
Good fluid should be a nice red colour and should have no real smell. Bad fluid is brown and will smell burned.
On your car the transmission fluid should be changed every 20,000 miles (32,000 kms). The filter clean/change was dropped from the service schedule in 1990.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Cassman500
i checked the fluid. it was a dark redish brown, no smell and the level seemed to be fine. it doesnt shift until the engine is reved up and then i take my foot of the gas. is it my timing belt or anything else i could check?
billofdurham
How did you check the level?
Bill.
Previously:
Cassman500
i drove the car about 20 minutes away where i take classes. left it idling in park, pulled out the dipstick, whipped it off then re-inserted it and checked it. it was normal, then i shut it off and repeated the same process and it was a little higher. i believe its more then the fluid because of the shifting and the noises i hear. i just want to know what else it could possible be. a check list of sorts, even if its ten items long, i want to figure it out.
billofdurham
Near enough on the fluid check but the attachment has the recommended method. It also has the only other thing I can think of to check as auto boxes are a specialist job.
Servicing.pdf
(237.26 KiB) Downloaded 523 times
I would recommend that you replace the fluid and see if that makes any difference. Otherwise I think you should visit an auto transmission specialist who should be able to give a diagnosis.
Bill.
Previously:
Cassman500
i had my ATF exchanged today and i also added a bottle of lucas, it seems to be running better i hope that solves the problem. Thanks for the help.
billofdurham
You are welcome. Thank you for the update.
Bill.
Previously:
