it should set a code when it fails to activate.
ECM 6110
WHen I get out to the garage i'll see if I can get 11v on high speed, mine might be different being 2004 v70.
Mine ran ok with no fan unless I let it sit idling.
V70 cooling fan p/n 30749759
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
I hooked it up to vida this morning, low fan speed is .30v , highest fan speed is 1.33v.
that reading is at the fan plug, from signal to fan ground.
Using my computer safe test probe all I see is very faint light, so its quite low voltage.
11v might be backfeeding from your neg wire, so make sure to connect pos to the signal wire.
Theres no other way the purple wire can get 11v as I see.
- 1171 Views
Last post by precopster
- 556 Views
Last post by Volvonoob84
- 3707 Views
Last post by s10lowrider1994
- 885 Views
Last post by Ozark Lee
- 744 Views
