Check this forum
https://www.volvoforums.org.uk/forumdis ... 7e2a&f=112
I think they got the 2011 2.0T in the UK
You may want to post your question there
Thanks
Paul
Power steering pump failure - twice
Thanks Paul
Found the part number 36001204
31280865
Bosch KS01000118
If anyone else is looking hope this helps
I need now to check matching part numbers in other manufactureres as it might be more available if at all
31280865
Bosch KS01000118
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 120 times
- Been thanked: 189 times
I don't see any cross reference for other makes in addition to Volvo.
That pump is very similar to what I have on my 3.2 S80 and LR2.
Make sure that the low pressure hose that supplies fluid from the reservoir to the pump isn't pinched. If you restrict the flow then the pump won't work.
The pump moves a lot of fluid.
Good luck
Paul
Good luck
Paul
Hi
To update i got the land rover reservoir
And last week got 36001204 pump
Installed them worked fine all the weaning noises disappeared
Steering is not heavy . But i feel it should be a bit lighter compared to other cars.
So not sure if there is something i need to check further
In the first time the stearing was super heavy and became lighter on driving
But in the second replacement it was light and then after some time the weaning noise started
Now no noise . Light steeering not heavy but i feel it can be lighter a bit
Regards
Regards
- 1257 Views
Last post by RobsS40
- 3485 Views
Last post by afa7afa7
- 1363 Views
Last post by Nevada1906
- 25 Replies
- 11001 Views
Last post by erikv11
- 3678 Views
Last post by jalwlb
