96 850 Fluctuating idle/stalling (VVIS?)
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
How about getting live data on some of those sensors..... TPS would be good to know.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
cheap850
- Year and Model: 1996 850 2.5-20V
- Has thanked: 1 time
I measured the resistance on the (disconnected) TPS as noted in my earlier post. After some research it seems good, it matches up with the values others have posted. There's no drop anywhere on the rotation either.454cid wrote: 16 Jun 2022, 12:28 How about getting live data on some of those sensors..... TPS would be good to know.
O2 sensor (OEM) should arrive saturday, if it doesnt solve the issue I'll just return it :-)
cheap850
According to this wikipedia page, this might acually be the original B5254S engine, equipped with V-VIS and available on the 850 through 1995-1996. I'll check the sticker this weekend.
https://en.m.wikipedia.org/wiki/Volvo_M ... ine#B5254S
- misha
- Has thanked: 155 times
- Been thanked: 432 times
I recently read a brochure for 850,online,made for Dutch market only.
It might be it.
Something like 2.0 T5 R made for Italian market only.
One thing is for sure...i have never seen or came across a '96 with VVIS and LH 3.2 Jetronic management.
'92-'95 yes....but no '96.
It might be it.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
454cid
I had troubles trying to do that. I couldn't seem to keep the probes on the connectors reliably enough, but it didn't matter. I already had it replaced, as I had used the 850 OBD2 app to graph the voltage of the TPS, and saw the voltage spike to 5 volts a couple of times, which did not correspond to me opening the throttle. I also took a look at the o2 sensor voltages, and found those to be off.cheap850 wrote: 16 Jun 2022, 14:15I measured the resistance on the (disconnected) TPS as noted in my earlier post. After some research it seems good, it matches up with the values others have posted. There's no drop anywhere on the rotation either.454cid wrote: 16 Jun 2022, 12:28 How about getting live data on some of those sensors..... TPS would be good to know.
Most places won't take back electrical parts, especially if connected.O2 sensor (OEM) should arrive saturday, if it doesnt solve the issue I'll just return it
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
cheap850
misha wrote: 16 Jun 2022, 16:40 I recently read a brochure for 850,online,made for Dutch market only.
It might be it.
I can confirm it is indeed the B5254S
cheap850
For whoever is reading this troubleshooting their own idle issues: if it runs just as bad with or without the O2 connected, its probably your O2 (lambda) sensor. My problem has been resolved with a new Bosch unit.
Still has some slight idle issues but it actually runs now, I suspect my MAF is also part of the problem.
Everyone thanks for your suggestions!
454cid
It would be interesting to know what your old O2 was reporting. Mine had been reading very low, so the computer was over fueling the engine trying to compensate for a false lean condition.cheap850 wrote: 18 Jun 2022, 03:42 For whoever is reading this troubleshooting their own idle issues: if it runs just as bad with or without the O2 connected, its probably your O2 (lambda) sensor. My problem has been resolved with a new Bosch unit.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
cheap850
I havent been able to pull live data, but I suspect it was the same issue as it did make the engine run very rich.454cid wrote: 18 Jun 2022, 03:57 It would be interesting to know what your old O2 was reporting. Mine had been reading very low, so the computer was over fueling the engine trying to compensate for a false lean condition.
- 18 Replies
- 2968 Views
Last post by lummert
- 1585 Views
Last post by Build
- 4625 Views
Last post by Georgeandkira
- 788 Views
Last post by LanceALatte
- 540 Views
Last post by MoVolvos
