Is nuclear power's time finished in the US?
Forum rules
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
With enough good energy storage, power three months a year is good enough!
:lol: :lol: :lol:
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
True, true 8)
Also -> Amazon link
Has thanked: 1610 times
Been thanked: 4065 times
If we could release the energy fusing rubber and metal in the rear delta links we will be all set.
Q: where do nuclear scientist go on holiday?
abscate wrote: 04 Aug 2022, 03:50 If we could release the energy fusing rubber and metal in the rear delta links we will be all set.
can't wait any longer for this answer.
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
volvolugnut wrote: 02 Aug 2022, 12:48 With enough good energy storage, power three months a year is good enough!
In the 70s the French inventor Jean Pain came up with a composting system that will produce hot water for about 18 months before it needed to be recharged. It "waste" product is Humus . It does not produce electricity but it will provide Domestic Hot Water ( DHW ), which is about 1/3 of a house's energy consumption, and heating.
If you want a alternative energy project to do, DHW has the highest Return On Investment ( ROI ).
https://www.motherearthnews.com/organic ... z80mazraw/
Active
Past
I recall in this town in the 1980's, many newer homes had small solar panels on their roof. They were maybe 20 to 30 Square Feet. I understand they were for hot water (DHW) only. I never had one or knew much about them. I think they have all been removed.
I have read of central heating systems for towns used in Europe. The bottom of the heat cycle from a power plant is great for building heating. The drawback is the cost of all the piping.
RickHaleParker
volvolugnut wrote: 30 Aug 2022, 16:38 I think they have all been removed.
Because they where built by fly by night companies out of Copper pipe and Aluminum flashing which are dissimilar metals ... Galvanic Corrosion killed them in about 20 years time. If you should built one, avoid that fate.
Active
Past
RickHaleParker
volvolugnut wrote: 30 Aug 2022, 16:45 The drawback is the cost of all the piping.
Anything that involves moving earth or trenching is expensive. That one of the reasons Geothermal did not catch on.
Active
Past
volvolugnut wrote: 30 Aug 2022, 11:34
They go fission, of course......
Im here the rest of August..
Try the veal
Tip your waitress
