This may be a long shot (and already mentioned?) but on my '94 there is a switch / sensor / module above the fan on the backside of the radiator, that triggers the fan control. Ours failed and it overheated twice in short succession. Many years ago - that may have been one of my first searches of MVS fixes!
But as abscate said, fogging windows in the summer points to coolant getting out of the heater core or hose connections at the firewall. No pressurized cooling system -> way lower boiling point. I changed the heater core in my 850 long ago.
‘97 850 Wagon Topic is solved
850oldschool
- Year and Model: 1996 850 NA
- Been thanked: 45 times
Do you have another cap you can try?
andrewjllrar
- Year and Model: 1997 850
- Been thanked: 2 times
Well, thanks to Robert, I think I’ve found that my radiator fan isn’t kicking on. Looks like the connections are good. Anyone know how to test the relay? No fuses, right? Didn’t see one in the fuse box list.
andrewjllrar
New cap- new tank
Heater core replaced relatively short time ago
No more fogging
No smell of coolant inside the car- no wet carpet
No drips under the car- other than when the coolant spills.
No more fogging
- manovlov
- Year and Model: 1995 850 GLT 2.5 170
- Has thanked: 620 times
- Been thanked: 143 times
Consider my intervention as a newbie one :andrewjllrar wrote: ↑10 Aug 2022, 09:35
Weird thing is, temp gauge reads normal (which it did before the gasket blew), water pump was replaced not too long ago, thermostat was pretty new- but sat for two years (top hose heats up fine). I can’t remember if I heard the fan or not- but again no temp surge on the gauge.
If i understand well, the cooling liquid is hot, but the gauge says everything is fine. Why the fan doesn't switch on, could it be an electric problem ? Maybe a silly question, but are you sure to have feed the coolant system as it should be ? Volvo says 7,2 liters for a 850. You said you get some liquid on the ground, 7,2 liters make a huge trace. Are you in that case ? You said the water pump has been replace, was it a OEM one or an after market ? I've learn here that to try to win some money with after market parts is the best way to loose money and especilly time (because to have to do the job twice, at least...).
andrewjllrar
Under the overflow tank when it overflows and falls to the ground around the passenger tire.
This also means I haven’t lost all 7.2 liters. Just have to keep topping it.
Yes, I don’t go cheapie on engine parts.
andrewjllrar
Black Bart wins the guesses with a bad radiator cooling fan relay. Jumped per Robert DIY's video instructions and it engaged both high and low speed.
Question now: no 850's currenty at the junkyard. Does a '98 V70 have the same relay?
- Has thanked: 1848 times
- Been thanked: 1710 times
According to the link from IPD the 850 and later cars are the same:
https://www.ipdusa.com/products/22967/A ... sUQAvD_BwE
You probably already know that the relay slides in under the cowel. Careful when removing it as it is easy to break it or the wires/clips when they have been on there a long time. A spray of silicon oil or WD40 around the connectors and then careful use of a pair of adjustable pliers can usually remove them without breakage!
Good Luck!
Good Luck!
andrewjllrar
Thanks Neil, but whatever was in that plastic housing had already just crumbled into rot. Could be what caused the initial blown head gasket in the first place. So, now some splicing and connecting I guess.
- 826 Views
Last post by manovlov
- 930 Views
Last post by Jeffkindelspire
