Is harmonic balancer wobble normal? Topic is solved
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 187 times
Post by dikidera »
DonnVa wrote: 18 Nov 2022, 18:20
dikidera wrote: 18 Nov 2022, 13:10
DonnVa wrote: 17 Nov 2022, 17:25 After I did the timing job, plus new serpentine belt and tensioner on my S60 the harmonic balancer was wobbling. I replaced it with a aftermarket one from FCP. No wobble after that. I think mine was caused by an old balancer and new (tight) belt. It just showed it’s age.
Did you notice a change in engine vibrations? Particularly an increase in them?
No not really. Both the S60 and XC70 have a little vibration at idle in gear. I haven’t gotten to all the bushings and sub frame mounts on the XC yet, but will in the near future. I did replace sub frame bushings and mounts except the two big front and back ones on the S60 and I didn’t really notice much of a difference.
Well since we don't have a brand new S60 P2 we can't say if there should be idle vibration in gear. All I know is after replacing 3 of my engine mounts, I got more vibration than before with the broken ones. Yes I did not use genuine volvo for 2 of the mounts and I think this is it, but we will see.
dikidera
Post by dikidera »
jonesg wrote: 17 Nov 2022, 02:34 that wobble can originate in the crank gear the timing belt runs on.
Check that the timing belt isn't wandering on the cam gear sprockets.
Check the 4 10mm bolts holding the harmonic balancer are torqued tight.
Remove the belt and check the balancer grooves are clean, inspect the belt.
I see the inner edge wobble but the outer edge looks steady.
Check the belt tensioner for smooth operation.
Ok, so I checked...there were only 3 bolts! One was definitely missing and not there. Could this have caused the perceived wobble?
Has thanked: 1609 times
Been thanked: 4065 times
dikidera wrote: 22 Nov 2022, 14:37
Oh yeah. Don’t listen to any Scots who might tell you to remove a third bolt to rebalance it , and then sell the bolt off.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
there ya go then.
check the big crank nut is tight too.
