If you peel the rubber coil boot down from the top, typically you will see at least one crack normally on the opposite side to the connector running from the top.
When you washed the engine, although is should not happen it may be water did get passed the boot and is sitting down at the bottom of the coil boot causing a short.
May be worthwhile removing the coils and then removing their boots and making sure they and the area at the top of the spark plugs is dry as well as the connectors on the coils. Remove the coil boots and bring the coils in overnight and let they sit somewhere warm to make sure there is no moisture in any cracks if there are any.
Washed engine, now it is misfiring. Any ideas?
- Has thanked: 2196 times
- Been thanked: 1850 times
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 117 times
- Been thanked: 271 times
Thanks, I'll check that out! I had a big order from FCP that I was putting together so I ordered a 5 piece coil set and will get them all changed out, they're originals so at the least ill have 4 spares. I will pull the boot back and see what things look like on the bad one though.
2003 XC 70 (sold)
- 780 Views
- 12 Replies
- 6063 Views
Last post by SuperHerman
- 924 Views
Last post by mrscullini
- 1468 Views
Last post by GBS
- 4720 Views
Last post by precopster
