1997 850 won't accept fuel at the gas station. Topic is solved
MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Post by MrAl »
454cid wrote: 29 Dec 2022, 11:56 Assuming you're not trying to fill a full tank, it's got to be a venting issue. I've had that happen on a GM work van. On the van the whole evap system was under the vehicle next to the tank, and the official word from GM was that "spiders" would nest in some hole and plug it up. I think it was just a poor design given the location. Thankfully my truck has the more traditional setup with everything under the hood.
I have no idea where things are located on the P80 Volvos. I'd starting looking at lines, valves, whatever in the evap system if someone else doesn't come along and provide something more specific.
That's interesting we have spiders that live in the side rear view mirrors in the summer.
A little bulb grease or brake grease around just inside of the mirror case and they hate it so dont hang out there anymore.
It's not just my car either it's other cars in the driveway also.
The bulb grease or brake grease lasts a very long time and it only takes a very thin coat. Spiders dont like to walk on some surfaces or items because they can taste with their feet and they dont like some tastes (ha ha). I think they also dont like surfaces they cant get a good grab on either, the grease is probably like a sheet of slick, wet ice to us.
moses3
Year and Model: 1997 850 GLT
Has thanked: 68 times
Been thanked: 5 times
Post by moses3 »
I drove 150 miles and the problem went away on its own. I will report back in 1,000 miles.
Has thanked: 2200 times
Been thanked: 1852 times
Well that is good news indeed! I think it is likely condensation or water in the fuel and possibly the roll over valve froze preventing venting.
Has thanked: 1610 times
Been thanked: 4065 times
Many solutions to the spider problem, naturally, searchable on the web.
moses3
Post by moses3 »
UPDATE: I've driven 2,000 miles and the problem hasn't returned. I would like to add that I recently remembered before the problem happened I had done 2 things on the same day. 1. Added a fuel system cleaner, and 2. Let the fuel tank get down to below the "2" mark.
It's likely that one of these factors or the combination of factors led to the issue...
Since then I have kept it above the 6 mark, and use premium fuel.
