Check Air Box Temperature Control Flap
MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Post by MrAl »
abscate wrote: 25 Jan 2023, 03:46 On the 1998 the thermostat lives up in the air box with the two vacuum connection hoses. Stock is hard nylon hoses with rubber connectors but often these have been replaced with vacuum line
Oh ok sounds like maybe i should bring the air box into the house for inspection and work on the thermostat?
I should be able to measure the temperature you were talking about at some point if everything goes well. If my thermostat turns out to be working, then maybe sooner than later.
You think it would be enough to measure the temperature it starts to close the little flap?
Oh and i should have thought of using Kaplar tape on the metal hose, it's the end close to the air box anyway so probably not as hot.
I wonder how hot the end at the exhaust manifold gets.
Has thanked: 2205 times
Been thanked: 1852 times
Good luck with that Al! Weather here is currently snowing. Typical weather forecasters here. Don't know their ass's from their mouths as the proverbial comes out of both. Today was forecast last night as clear and 4C. Planned a junkyard run as only decent day this week before the -15C weather hits again on Friday for the foreseeable future.
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
Any idea when this changed. My 96 is like that too.
Vacuum line? I used vinyl air line for my fish tank 8) (Until I removed the system),
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Has thanked: 1610 times
Been thanked: 4069 times
We should write up a quick FAQ on this system
Engine vacuum
White hard line to air box
Thermostat in air box
White hard line down to air box motor
Without vacuum, what is status of air box motor?
Does thermostat open to provide vacuum or close to inhibit vacuum?
What temperature does it open or close ?
Is it digital or does it ramp vacuum to control temperature
I would gladly help but have no NA air system stuff other than the flexi hose to the exhaust manifold.
MrAl
Post by MrAl »
454cid wrote: 25 Jan 2023, 09:18
Hi,
That's an interesting idea. I think i have some of the silicone type around. Dont think i need any right now though.
MrAl
Post by MrAl »
abscate wrote: 25 Jan 2023, 09:41 We should write up a quick FAQ on this system
Engine vacuum
Hi,
There is a motor too?
Geeze Volvo why not make things as complicated as possible ha ha.
MrAl
Post by MrAl »
scot850 wrote: 25 Jan 2023, 09:51 I would gladly help but have no NA air system stuff other than the flexi hose to the exhaust manifold.
Consider yourself lucky ha ha.
I guess your weather is worse than ours here in lovely NJ ha ha.
It was raining all day today though. I never mind the rain except when i have to go out, or work on the car.
