I am continually surprised how inexpensive these are to maintain
wheelsup
Has thanked: 15 times
Been thanked: 20 times
Re: I am continually surprised how inexpensive these are to maintain
Post by wheelsup »
FireFox31 wrote: 01 Jun 2023, 22:30 Flaring a new line is easier than replacing the line because you don't have to remove the old and bend the new to match. Simply cut off the old fitting as close to the end as possible, slip on the new one, then flare the line. The line will be a little shorter but that's usually ok.
Yes, I'm not describing the entire process. YouTube could walk you through it as it did for me. I've used this flaring skill a bunch in recent years due to stuck fittings (on Volvo) and rusted lines (on Mercedes).
I have to admit it would be pretty empowering to just fix the line and not have to worry!
Out of curiosity do you remember the size of the fittings etc I need?
After I posted this thread I did attend Youtube University and the process looks fairly straightforward, however things never go as planned for me regarding car repair.
wheelsup
Post by wheelsup »
abscate wrote: 01 Jun 2023, 20:01 My Tar Heel Geography needs work. I forget that RTP and Charlotte are a hike apart
I make the drive about once a month, sometimes more, as I work out of CLT airport. Yeah, about 3 hours.
FireFox31
Has thanked: 158 times
Been thanked: 300 times
Post by FireFox31 »
wheelsup wrote: 02 Jun 2023, 10:47 Out of curiosity do you remember the size of the fittings etc I need?
The rear caliper fittings are M10 x 1 bubble flare. However, before you try to remove yours, know that the caliper fitting holes will have closed up due to rust, grabbing the fittings, making them hard to remove. Before you can install a new fitting, the holes need to be bored out to the correct size with an M10 x 1 tap. I have not yet done this but need to on some calipers.
If your rear calipers are working but their fittings are stuck, you're best off leaving them in place. Examine the boots for breaks and the pistons for proper movement with the calipers on the car. I started a draft thread about caliper failure but haven't filled in that info yet.
FireFox31
jmartin919
Year and Model: S70 GLT SE 2000
Has thanked: 94 times
Been thanked: 39 times
Post by jmartin919 »
wheelsup wrote: 01 Jun 2023, 11:36
abscate wrote: 01 Jun 2023, 02:53 A Neiko flare kit and some NiCopp is cheaper than a premade line. Flares are easy, even this guy can do them….
It's too bad you're not closer to me, would love to share knowledge like this and have work-on-our-cars-days! Because I have no idea what you are talking about lol.
Hit me up some time, I live in Durham.
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 333 times
Post by Chuck W »
wheelsup wrote: 31 May 2023, 23:15
Also, couldn't you just replace with something like this?
Stainless Steel Brake Line Kit 1993-1998 P80 850 C70 S70 V70
Why the need to flare/make a new lineset?
These are replacements for the RUBBER hoses, not the hardlines.
Sometimes it's easier to replace a fitting and re-flare an existing line. Sometimes it's easier to just replace the whole hardline.
As abscate mentioned, the NiCopp hardlines are great. They can easily be formed and flared, and they don't rust. I've used NiCopp stuff for lines on my F150, my Thunderbird, my LTS, my 850, and my wife's 76 Beetle.
FireFox31
Post by FireFox31 »
I had to bend a really wacky line for my old Mercedes. With NiCopp, it was a little tricky to make the bends without flattining the line. My line bender tool had too large a radius for what I needed so I tried bending it over a pipe. What methods do you use to get good bends on NiCopp?
FireFox31
Has thanked: 1497 times
Been thanked: 3810 times
Bend it around a socket of the same radius as the curve needed. It’s a bit of art here
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
Use big sockets and gently work it around the radius. Don't do the whole curve at once.
wheelsup
Post by wheelsup »
jmartin919 wrote: 08 Jun 2023, 11:01
Thanks, will do
