1996 850r Instrument panel stays on when key is out
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
If the lights were dim and brightened when you turned the key,
that sounds kind of like a sticky relay contact to me. I'm surprised
that no other systems were affected, though.
Relays 105, 106 and 107 are identical, making it pretty easy to pull
and swap them to isolate and see if the problem follows a relay.
You may want to mark them before you get started.
96 850 Relay Locations.pdf
(167.81 KiB) Downloaded 71 times
Texasbrainstew
Year and Model: 1996 850 R
Has thanked: 1 time
Been thanked: 3 times
Post by Texasbrainstew »
I FOUND THE FUSE
Its fuse #3 !!! (When connected keeps my dash warning lights on with the key out)
I can start the car 100% and have all of the normal behavior from the cars lights with the fuse completely out.
When I turm off the car behavior is normal as well.
So weird! "Courtesy lamp control signal, CAT converter overheating warning, speed warning"
Im desperate to find the schematics for this circuit.
ALSO I already tried pulling both overload relays with no luck at all. Lights still on with key out. EXCEPT when fuse #3 is pulled
*update: my key fob works fine now too. Now that fuse #3 is pulled.*
Any thoughts???
Has thanked: 1613 times
Been thanked: 4078 times
1996 electrical diagrams are not hosted here by agreement with Volvo, but links are findable by search
BEJinFbk
Post by BEJinFbk »
You're looking for Technical Publication:
TP3911202 850 1996 Wiring Diagrams
Texasbrainstew
Has thanked: 1 time
Well well well. Seems like it was only temporary.
With that same fuse pulled, my cluster is on again when I pull the key out.
Texasbrainstew
Has thanked: 1 time
The original fuse I pulled was #3 courtesy lights
When I pulled the fuse #2 for the fuel pump the lights turned off. Any suggestions?
Has thanked: 2215 times
Been thanked: 1853 times
Shorts under the main fuse box. Wires may be perished and shorting under there.
Each time you play with a fuse you are moving wires with shorts or opens. Tough to logic troubleshoot,you have to get down and dirty and inspect the wiring , including the stuff under the tape wrap
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
You could be chasing a ground issue too.
And that cluster of wires going under the relay container is a known sore spot, my early 850 did really goofy stuff when that mess got cruddy.
