Help diagnosing bad engine sound *solved* Topic is solved
greffel
Year and Model: 2003 S60
Has thanked: 11 times
Been thanked: 8 times
Post by greffel »
Questions:
We replaced the automatic gearbox 1,5 years ago, could this be a torque converter that got loose from the flywheel?
Options:
What's the easiest way to diagnose bad rod bearings ?
Can I remove the sparkplugs and press down feeling for play ?
More info:
The car runs normal, with no power loss och faults codes in VIDA
Between 1300 - 1800 rpm the sound is most prominent
If I remove the oil cap there is no more sound, it feels like a bottom engine problem ....
....please guide me :)
Polestar 2 - All electric daily driver :shock:
S60 2.5T AWD with a little bit more power :evil:
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
The Volvo 2.5T engine can sound like a diesel engine too.
If you have no issues, just keep an ear on the noise.
I change oil with synthetic every 6K-7K miles.
jonesg
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
greffel wrote: 07 Jul 2023, 08:48 Questions:
Options:
More info:
Yes it could always be the previous work you did, always return to the scene of the crime....and double check.
rod bearing test, needs 2 people...
remove spark plugs, use a wood dowel to ride on top of the piston, rotate engine manually to just beyond tdc , as piston has started to descend, stop rotation and press down on the dowel. If theres any slop in the bearings you will feel it click.
I would say turbo or flywheel, they are easy to check
Engine cold, put your hand on the turbo and start it up, rev it til you hear the rattle, if its the turbo you will know .
Also check the wastegate isn't flapping around, the linkage can fail.
If nothing found, and before the engine warms up , move your hand quickly to the flywheel area and see if you can detect it by feel.
Geraldt
Year and Model: S60 2.5t AWD 2003
Post by Geraldt »
Hi,
My dad is currently away from home for a while. I will continue to troubleshoot along as I am comfortable with what I am doing. Tomorrow the plan is the following:
1. Remove the skid plate underneath the car and check whether or not I can feel any severe rattle.
2. Check if I can feel anything around the turbo. In a week I might be able to get my friend to help me do the rod bearing check.
I am very thankful for all the help and assistance :)
Has thanked: 1609 times
Been thanked: 4065 times
That’s the rear of the engine, left side of the car. I think that’s a bad rod knock. Try pulling the coils on 4 and 5 one at a time and see if the noise changes
That’s my plan B guess.
Pull starter and inspect. Maybe visible by removing crank sensor?
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
The engine is FUBAR. Rod knock.
Also in the next engine change oil more frequently than once a year.
Geraldt
Post by Geraldt »
jonesg wrote: 07 Jul 2023, 14:15
Options:
More info:
Hi,
I did check the turbo and flywheel using feel. I can't feel any unusual rattle or knocking. I'm a bit curious about the comments highlighting possible rod knock. As we said before the sound is only present when being on idle up to about 2k rpm. Can it be the flywheel getting stabilized because of the forces? If this was rod knock wouldn't the sound get worse when the RPM is higher? The engine sound fine when above 2k rpm. I have ordered a endoscope and I will do the piston check as soon as it gets here. When I check the pistons can I use anything that is hard enough and doesn't leave any kind of debris on the piston? For example the handle on a 3/8 ratchet?
jonesg
Post by jonesg »
a mechanic could diagnose this in 2 minutes.
greffel
Post by greffel »
Back from vacation and one week to fix this issue :)
This morning we looked inside the cylinders with a endoscope and the cylinder walls and pistons look fine. ( see pictures)
Also we tried to feel for some play pressing down on the pistons but no play at all.
This was done with the pistons on the way down in the cylinders.
Then we tried to disconnect one ignition coil at the time but the sound does not go away.
It's so hard to tell 100% where the sound is coming from, is the next step removing the oil pan or can we do any other smart test ?
vtl
Post by vtl »
Removing oil pan, cleaning pickup tube screen, installing a new O-rings is a wise move for any P2 in 2023.
Third picture has some overheating signs.
