1999 V70
pfmet
Year and Model: V70 1999
Has thanked: 44 times
Been thanked: 22 times
Re: 1999 V70
Post by pfmet »
Autocorrect turned my colon-close parentheses into a smiley face. I DID NOT use an emoji!
FireFox31
Has thanked: 158 times
Been thanked: 300 times
Post by FireFox31 »
Get the green retainers and the pair of yellow o-rings for each hose. Cheap way to prevent leaks.
FireFox31
Has thanked: 1505 times
Been thanked: 3818 times
I put a Nissans on my T5 and it leaked after 5 years. The cause was a bad install , I let the jury rigged mount ear break, which mount huge stress on the upper hose mount and side case
Has thanked: 1850 times
Been thanked: 1712 times
It is worth buying those as mentioned by Firefox I think. The green clips tend to go brittle, and the 'O' rings go hard and can split if you try to re-use after being in there a long time.
That is a really good price on the alternator, and yes those mounts are worth getting. Some radiators come with them but others not. Also keep the metal center piece from the side (main) mounts as they prevent the rubber collapsing and keep it's shape.
If you have not already done it, start soaking the 2 side mount bolts now and daily until you get to the job. The bolts like to seize and break the captive/welded nuts off..
wizechatmgr
Has thanked: 45 times
Been thanked: 126 times
Post by wizechatmgr »
abscate wrote: 25 Jul 2023, 04:07 Behr was OE , and I think now they share marks with Valeo
Soon, all car parts will be Taco Bell
Sounds delicious... I better stay away from it... =)
