Volvo S70 2.5T P0422
Ninjakush
- Year and Model: 1999 Volvo S70 2.5T
- Has thanked: 3 times
I did some more smoke testing after your comment, and I found some leaks on the intake plastic it self, now im trying to figure out where I can buy that, so far I've only found do88's custom intake
- Clemens
- Has thanked: 500 times
- Been thanked: 228 times
Big question: has it ever passed smog in the past with the dp and 350 cell cat? if not, I would highly suspect these mods. if it has, look elsewhere.
scot850 has a very good point. a bad ETC would screw everything up, including cold start idle. Be sure to buy a good quality part.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- Goupil
- Year and Model: 98' V70 LPT
- Has thanked: 30 times
- Been thanked: 114 times
For reference, I have a Ferrita downpipe with a 200cell cat on my car, it's tuned for E85 and I got through inspection.
0.1% CO at idle and 0.25% when revved up (I think around 3500rpm), 0.998 lambda.
I usually drop my car for the day at the inspection place, but with the sport cat I drove it hard right before the inspection to get the cat real hot.
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
- Has thanked: 2205 times
In Sweden, check GCP.SE for OE parts. They bought Volvo's part for older cars and supply Volvo Classic with parts.
A few years ago I found and bought an intake snorkel tube from the airbox to the turbo at: junk.se
Ninjakush
Got my hands on a new intake snorkel, volvo original, drove it on 98 octane with no issues, Tried 95 octane E10 when my 98 was out and got engine light same code, I think I might have to go to a new tuner, Maybe the map was poorly made… thank you guys for all the tips and tricks, I will be swapping the ETC even if it might be fine it’s surely time for it anyways since it’s so old, Also my long term fuel trim hangs around 8% -9% with the new intake, Pretty high? I did a full reset when I swapped it, Removed battery for 30 minutes
In Europe, I seem to recall Vernet made the original ECT. We don't get the option to buy that over here. It is that or OE only we have found.
Good Luck!
Should add that E10 fuel is supposed to work with our cars but no higher than 10%.
Good Luck!
Ninjakush
Well, Just my luck, since I got my hands on the last fresh air intake I guess, I did another smoke test to make sure there was no leaks anywhere! Well guess what, The new intake with the premounted PTC /Grommet leaks a lot
Ninjakush
Small update, fabricated my own fresh air intake, With aluminium pipe and silicone hose, Welded nipples for the vac lines and PTC, I smoke tested the vehicle, there is no leaks in any hoses, no smoke coming out, also checked under the engine cover no smoke, when I open the oil cap smoke pours out, so its safe to say its not leaking? However, im still getting large Long term fuel trims around 11-12.5%! And Short term fuel trims at 4 to -4 % is this normalt for a tuned car? Or where should I start looking now? Will update pictures of the OBD TRIMS when I get home, as well as with MAF and coolant temps.
Ninjakush
once I parked to cooldown the vehicle the coolant temp went up to about 102-105 celcius, And the fan did not turn on? as someone commented before I am replacing the ECT If that has something to do with that?
The engine shows no hesitation, However when I am starting the car, the first few seconds when it's cold it's still sputtering, this disappears real quick. Uploading video.
Anyone got any ideas what I can do now? I'm going mental
02 sensor.mov- Video of 02 Whilst driving highway 90 KMH
- (3.02 MiB) Downloaded 68 times
Fuel trim idle.mov- This is the fuel trims on IDLE
- (7.54 MiB) Downloaded 74 times
Cold start sputters.mov- Cold start sputters
- (1.57 MiB) Downloaded 72 times
Ninjakush
Did like you said installed a new cat, went from 0.8 CO 2500 to 0.5 still not passed.abscate wrote: 24 Aug 2023, 08:14 The long term fuel trim tells you the car is running very close to stoichiometric. Simply out, the cat is not covering CO to CO2 so you fail emissions.
Solution. New cat. Cost will tell quality
Co 0.0 (0.5)
Co 2500 0.5 (0.3)
Lambda 1.03 (0,96-1.04)
HC 33 (200)
These are the results () is the allowed without is my results.
Also replaced ECT, Termostat, Fuel filter, filled up the tank with 98 octane.
Did a smoketest for 2 hours no leaks.
- 912 Views
Last post by jvl
- 1267 Views
Last post by JBC2565
- 1315 Views
Last post by Soloarmadolo
- 650 Views
Last post by dosbricks
- 2514 Views
Last post by erikv11
