i did this a while ago, but because i didnt round the corners of the cut the plastic over some time started to crack/tear. Thats why aeroplane windows are rounded...
You can hardly tell which switch it is??...i did a heater core bypass a few summers ago and this switch turns the bypass on/off. Im soon to restore cooling system to normal as its not as effective as i was hoping.
DIY Tutorial: Adding aftermarket center console switches (under climate controls) 05-09
How To Add aftermarket buttons to console
- darylrobert
- Year and Model: V70 240 740t xc70
- Has thanked: 6 times
- Been thanked: 44 times
- FMradio
- Year and Model: 2006 S60
- Has thanked: 55 times
- Been thanked: 8 times
Haha. That looks nice. Thanks for sharing about rounding the corners, that's an interesting find and important if it's common for plastic to crack with a square edge.darylrobert wrote: 24 May 2025, 03:48 i did this a while ago, but because i didnt round the corners of the cut the plastic over some time started to crack/tear. Thats why aeroplane windows are rounded...
Your cut in the plastic looks very precise, what kind of cutting tools did you use?
Best wishes for the cooling system fix. It's neat you can even control a bypass valve with a switch!
- darylrobert
I think i used a dremel like tool. however this is my current mod project, getting OEM switches to work as on/off. I got the feel of the button as close to OEM using the original silicon boot they use on all switches apart from the audible click from the reverse mounted tactile switch. This particular switch will be used to open /close the garage door (we right hand drivers didnt get homelink) . I have another switch for my TPMS and im working on a third that will control a latching micro relay (ie turn on and stay on) for my front mounted camera.
- darylrobert
How to get a factory ECC switch to operate aftermarket accessories, using a modified switch connected to a LM 393 voltage comparator module. Basically the module detects a change in voltage as set by the user.
- darylrobert
ive added a TPMS on/off switch for my aftermarket setup. I had contacted some businesses that laser etch (same method used on OEM switches) and most said no but one said they could try, was too expensive so i had some vinyl stickers printed. looks better than that generic switch.
