Yes!
But this is like a 15 minute job, it's not like debris will be flying around. Using oil will also help to contain the swarf.
@ abscate which cam cover hole is it?
P80 Valve cover bolt Helicoil , oil leak 985135
- Has thanked: 312 times
- Been thanked: 818 times
- Has thanked: 1613 times
- Been thanked: 4078 times
I think front row , just under the number 2 coil plug.
Front row of the coil bolts, not the edge bolts
1 picture = 1000 words to come
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Yup, on both. I'll pull a bolt out of Old Blue, too.abscate wrote: 06 Mar 2024, 05:54 Hey Foggy - a little bird told me you have a cylinder head currently off a car. Could you measure or SWAG the thickness of the head for me at tthe point where the M7 cover bolts go? I will post the exact one to measure here
Tap threads
Clearance cam cover for M8 through bolt
In DC, back in DE in the AM.
If you already own a regular M8 tap, investing in a bottom tap to follow up would make a better job of it.
An Ancient Machinist, he of the boring matter above, taught me the trick of laying a little bit of grease in the flutes to help catch the spooge as well.
- foggydogg
From the parting line of the cam cover surface to the bottom of several blind holes I got ca. 22.97mmabscate wrote: 06 Mar 2024, 05:54 Hey Foggy - a little bird told me you have a cylinder head currently off a car. Could you measure or SWAG the thickness of the head for me at tthe point where the M7 cover bolts go? I will post the exact one to measure here
The cover itself at the bolt hole pad seems to be ca. 20.30, but I had a hard time getting a good read due to circumstances beyond my control ( the head is in an awkward spot, it was raining a Deluge, and I didn't feel like emptying the back of the car.)
- 11 Replies
- 19619 Views
Last post by volvolugnut
- 1314 Views
- 1592 Views
Last post by jeffsws
- 12 Replies
- 3836 Views
Last post by JimBee
- 20 Replies
- 5095 Views
Last post by ZionXIX
